Results 1 to 8 of 8
Thread: Steel of Acrylic Tub
    DIY Junior Member JEP's Avatar
    Ringwood, NJ
    Default Steel of Acrylic Tub
    I will be replacing the current steel bathtub in my bathroom. Cast iron is not an option for a few reasons cost etc. My choices are Steel or Acrylic. Is one better than the other? What are the pros and cons?
    I know both should be bedded in mortar. What kind of mortar is the best to use?
    Thanks John
    Default tubs
    The only two advantages to steel are that it is cheap and it is light, so it can be carried easier. I am not very fond of acrylic either, but if those are the only two choices you have, then it is the only one you should use.
    Ringwood, NJ
    Thanks hj
    Excluding cast iron, are there other choices I'm missing that I should be considering?
    Thanks John
    Ringwood, NJ
    I'm replacing a bathtub 60" x 30". I have found these two so far.
    http://www.americanstandard-us.com/P...asp?prodID=234
    http://www.lascobathware.com/browse....0-30&series=12
    Anyone here have any experience or recommendations as to which is a better option?
    Anyone have any better alternatives for this size bathtub (not cast iron)?
    Thanks John
    Ringwood, NJ
    I saw this at Home Depot for $299.00. I thought cast iron was much more expensive than this. Does anyone know if this is any good?
    http://www.us.kohler.com/onlinecatal...5&module=Baths
    Thanks John
    DIY Senior Member sulconst2's Avatar
    Jul 2005
    old bridge nj
    316 lbs for the kohler. thats a hump up the stairs. hard enough taking one down. american standard makes an americast tub. solid and lighter. good thing about acrylic, besides being light, is the color goes all the way thru. as long as the tub is installed correctly you would be ok. would not recommend the lasco for your own home. maybe a job were customer wants the something for nothing!
    Ringwood, NJ
    I know getting the Kohler cast iron tub up the stairs and in place will not be easy, but I'm thinking that down the road I won't be saying I should have.
    It seems some folks here are not crazy about acrylic and steel tubs.
    In the Trades plumbernj's Avatar
    Aug 2005
    New Jersey
    Default Get an Americast
    This is easy... get an Americast tub. Home Depot sells them.
