Oh great, it just keeps getting better............
The new "digital" control has yet to arrive but I was cleaning up around the heater in preparation for doing the work down there. I started vacuuming all the dust and cobwebs etc. from around the burner access. Tried plugging the unit in again just to see if it would kick in and now in getting the 2 - 3 error code which is the flammable vapor detector failure. I checked the connectors, they are not dislodged etc. I did NOT use any cleaners or water while cleaning, just a small brush and a vacuum. There are no chemicals or paints etc. stored anywhere near the unit.
So now I'm wondering if this was the actual problem in the first place as the earlier ECO failure seems to be a rather vague error. Is the ECO physically located within the gas valve portion of the electronic control/valve assembly component. Can the ECO and the FVD error be related or is it more likely than I have now created a new problem with the FVD? Hard to believe as I was very careful and gentle but..............
