Well Problems after 2 years of operations
milkman1
Network Engineer
A two year old well with a massive growth where the metal pipe meets the well pump, which resulted in a leak. As the pipes were pulled I saw several sections with heavy rusting spot which is NOT a good sign. Any suggestions on how to fix this situation? I'm mad as hell, any help or suggestions is greatly appreciated.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I wonder if anyone has tried using heat shrink tubing? By the looks of the picture, the tape they used was starting to unravel.
My guess is that the electrical service ground is inadequate and that there was an electrical current via the protection ground causing electrolysis to liberate oxygen from the water.
ShallowWellNovice
Southeastern NC
Does anyone know why a shallow well pump will produce a strong stream of water for 15 seconds and then die where no water flows for 8-10 seconds before pumping a strong flow of water for another 15 seconds. The pump will build up pressure and then turn off if I shut off the spigot I have on the outlet side of the pump. I have a small pressure tank installed. The vacuum guage I have installed indicates there aren't any suction leaks. The static water level is 11" with the well at 35'.What am I doing wrong? Any help will be greatly appreciated.
