Results 1 to 4 of 4
Thread: Cracked Cast Iron Stack or junction between toilet and shower
    DIY Junior Member cathychis's Avatar
    Sep 2011
    Harmony PA
    Default Cracked Cast Iron Stack or junction between toilet and shower
    Our house was built in 1937. Sometimes when this particular shower is in use, it leaks heavily into a closet on the 1st floor. Sometimes when the toilet is flushed, same thing. There is a tile floor in the bathroom. Does it sound like we need to rip up the floor to figure out what is going on? We just finished remodeling it... There's about 5 feet between the toilet drain and the shower drain. Thanks for your help.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    Or you could open the ceiling in the closet to see what is leaking.
    You remodeled it without checking the piping, or did you not redo the floor during the remodel? you can open the ceiling under the leak to see what is happening, (or make a small hole and have a plumber look inside with a small inspection video camera), but in many cases, you will have to break the floor in the bathroom to actually do the repair.
    Sep 2011
    Harmony PA
    Did not redo the floor during the remodel as the tiles are in great shape. Will try to check it out from below first, and maybe with some luck we won't have to tear up the floor. Teen girl wants her new bathroom back! O the pressure .
  1. Cracked cast iron 4-way Tee in Vent stack/sewer drain in bathroom
    By Rudy6897 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-18-2011, 08:40 AM
  2. Cast Iron Stack Leaking
    By AdamDH1972 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-19-2011, 04:37 PM
  3. threading PVC fitting into cast iron stack
    By ksudar in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2010, 07:18 AM
  4. Moving Cast Iron stack
    By Looney in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2009, 06:00 AM
  5. removing 4'' cast iron stack
    By tk2 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2006, 06:12 PM
