Results 1 to 2 of 2
Thread: Elbow With Low Heel Inlet to connect Tub & Sepperate Shower
    DIY Junior Member Erc's Avatar
    Mar 2011
    ATL Georgia
    Default Elbow With Low Heel Inlet to connect Tub & Sepperate Shower
    Can an elbow be used with the heel inlet in the vertical position for connecting 2 drain lines such as a separate shower and tub. I have seen posts that say this is not the intended use for this fitting, however it works, and that better practice would be to use a sanitary T with side inlet? The vent would be coming off the tub line a few feet away from the fitting. Everything connects to a vertical drain going to the floor below. I am trying to avoid drilling more holes in floor joists that are already drilled to death! Thank you.
    In theory it is the same as a full sized sanitary tee with a bushing, but you would have to run it by your inspector because some do NOT like heel inlet 1/4 bends.
    Here is a tee with a side inlet.
  1. Ok to use heel inlet 90 degree el
    By johnny92626 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2008, 12:44 PM
  2. offsetting mainstack and correct use of 90 elbow with heel inlet
    By johnk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2008, 07:24 AM
  3. PVC Fitting - Using Elbow w/inlet w/toilet drain
    By hmmdinger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-17-2005, 11:22 AM
  4. San Tee vs 90 with low heel inlet?
    By slb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2005, 06:09 PM
  5. removing elbow inlet pipes
    By johntrigon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-14-2005, 05:13 AM
