Results 1 to 15 of 15
Thread: Cold air flowing from well head
    DIY Junior Member sarasara's Avatar
    Sep 2011
    Washington
    Default Cold air flowing from well head
    I am looking at a piece of property that has a well on in. There is a strong flow of cold air coming out of the wellhead. It is loud enough to hear from several feet away. It is odorless. I have not noticed this on any of the other wells I have seen. Anyone know what this is? Is it good or bad? Thanks!
    Sara
    DIY Senior Member TJanak's Avatar
    Sep 2009
    South TX
    Pray that it's natural gas
    Travis
    When I need a precise measurement of something I often use the highly technical method of eyeballing it.
    Dec 2009
    northfork, california
    I have a well that blows out air when running only. Maybe your drilled through a cavern.
    Well driller,pump repair. and septic installer Waterwelldude's Avatar
    Feb 2009
    Texas
    Quote Originally Posted by TJanak View Post
    I hope you are joking.
    That is the dumbest statement I have ever heard.
    Its VERY dangerous, it can kill you if any spark comes close to it, it makes the well useless,
    and has the potential to blow the house up or anything else its plumbed to.
    "I shall never surrender or retreat" -Col. William Travis
    Feb 2009
    Texas
    Quote Originally Posted by sarasara View Post
    Sara
    Does the well blow the air after the pump shuts of or is it all the time?
    If its just when the pump shuts off, that is the well replacing the water that was just pumped out.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Think he was just joking....it was a reference to the amount of $$$ it could generate.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Waterwelldude View Post
    On a well that is a slow producer with a high GPM pump, the pump will draw down the storage in the well and subsequently suck air into the casing. When the pump shuts off, the well will refill, displacing the air from the well.
    Retired Cable Driller Clpixley's Avatar
    Sep 2011
    North Central Idaho
    Sarasara:
    My dad drilled many wells in the Spokane Wa. area. A few of them were wells that blew air out, and
    at other times the same well would suck air in.
    These well can be hazardous. There have been reports from the western provinces of Canada
    of people dying from breathing the air from these blowing wells while servicing the well in a well pit.
    As I recall, the air was't poisonous, but had a lack of, or insufficient oxygen.
    Dec 2009
    What makes a 50gpm 6" rock well BLOW air out when being pumped at 15 or 20 GPM? Its no air compressor, no odor, but a noticible breeze from a vent.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by ballvalve View Post
    Beats me. No explanation comes to mind.
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    Dec 2009
    VERY interesting aticle. Nitrogen is being touted as a means for self extermination lately, as its been disovered that you quickly pass out and die quick without any "kicking about"
    And I use it in wine barrel "topping" as it sits low and displaces oxygen. Have to be a bit more careful about sniffing the wine!
    Luckily in Ca. we dont have well pits.
    Nice thing I read about nitrogen is that it leaves no traces of death in the body. So if you are really sick, and do it carefully, you can still get the double indemnity pay off for the family.
    Jan 2008
    Virginia Beach, VA
    It's probably a cavern somewhere. It's usually not a problem but if it's in a pit you should stay out. Ocasionally some of these blowing wells will suck air at times. This usually means that the well cavern is storing or releasing barimetric air. I wouldn't be concerned!
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
    Dec 2009
    I would go dig for that cavern and sell tickets.
    Moderator valveman's Avatar
    Mar 2006
    There are some wells in central Texas that alternate from blowing air to drawing air all the time. I don't know if it is the moon phase or barometric pressure that determines if it is blowing or drawing but, it doesn't seem to bother anything else. Never get in a well pit without external air and help. Even one that is not blowing can be hazardous to your health.
  1. water flowing from shower head
    By scott580sm in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2011, 05:12 AM
  2. How to adjust hot/cold w new shower head
    By joekapahulu in forum Shower & bathtub Forum & Blog
    Last Post: 06-23-2008, 10:02 AM
  3. shallow well not flowing, help me fix plz???
    By wisil in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-23-2007, 10:22 AM
  4. water flowing from shower head without diverter pulled up
    By rbs4302 in forum Shower & bathtub Forum & Blog
    Last Post: 03-12-2006, 11:23 AM
  5. Low flowing water
    By Frank in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-14-2005, 01:02 PM
