Continually draining
Chevy427
USA
The resin tank is the tank under the control valve. Resin is the media that removes select contaminants and has a cleansing stage(s) that removes those contaminants. The brine tank holds the salt.
Generally, the size of the tank will indicate the amount of media (depending on the media) that is inside.
Gloch
Utah
The resin tank is approx. 44.5" to the valves and 28" circumference.
-gl
Rjh2o
Michigan
That is a 1 cu ft softener and will regenerate every 2-3 days with 7 people on that water with 0 iron. Make sure it is keeping proper time of day, if not the timer/drive motor needs replacing. If motor is bad it can be stuck in cycle. There may also be debris in the valve which can cause the piston to stick and run to drain. That system is too small capacity for your household. It may run every day if you are heavy water users.
Timer motor and piston are about $200.
RJ
