Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Continually draining
    DIY Junior Member gloch's Avatar
    Sep 2011
    Utah
    Default Continually draining
    I have a Fleck 5600se system in my household of 7 people. We just installed the system over 6 months ago but recently it started continually running water into the drain. After looking at the manual, it sounds like there is a broken piston(?) or something in the timer. I had a guy come look at it and he indicated 2 things (1 the system would cost more to fix than it's worth and (2 the system is not big enough for my family size.
    So my question is if the system is not capable of handling our usage needs and whether or not it should be fixed(I will do the repair myself) or replaced given the symptoms?
    -gl
    Dec 2009
    Alaska
    I would say that there is a seal that has a challenge..
    If you go through the book, you will find a page that shows the spacers, seals, piston and the body along with other parts.
    By putting it in bypass and starting a cycle to releave the pressure, the powerhead will come off and the plate under it and then the piston and seals and spacers come out... now for now you might try changing the line up of the seals ... ie taking the middle ones and moving them to the top and bottom .. Look them over at the same time to see if there are any breaks... or cuts...
    If the piston or seals and spacers need to be replaced there are is few spots on the web that the rebuild kits can be had and most likely under 60.00 and then your time to put it back together.
    What kind of water quality do you have?
    Almost sounds like some one trying to make a sale of equipment...but that is just me.
    Sep 2011
    Utah
    Thanks for the reply. I thought the same thing. It felt liek we were being sold a bridge
    With this system, do you think he was off-base in telling me it couldn't handle the usage?
    -gl
    Dec 2009
    Alaska
    Maybe....
    Depending on the water quality and the flow rate needed and the capacity needed.. it is possible.. but the questions would have to be answered first.
    Hardness of the water, Iron if any in the water..
    Bathrooms in the home.
    You said 7 people, any Teenagers?
    Sep 2011
    Utah
    Teenagers, yes. 3 of them. There are 3 full baths. The water without the softener is leaving a think coating on our dishes but, I still need to actually measure the hardness. I believe it is bad however.
    -gl
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Debri can get caught in the spacer & seal which will cause a constant drain flow or one of the seals is pinched. Either way, it is a quick fix with little cost.
    Dec 2009
    Alaska
    Quote Originally Posted by gloch View Post
    -gl
    With out the hardness number and the size of the system in question it is hard too say undersized, or oversized...
    Working with only 2 parts of the math problem is hard when there are other parts that need filling in.
    Sep 2011
    Utah
    Quote Originally Posted by mialynette2003 View Post
    When you say "spacer and seal" what part of the softener are you referring to? Control valve?
    -gl
    Nov 2010
    Ocala, Florida
    Yes. The base of the control valve houses the piston and spacer & seals. If debri gets caught in them, the seal no longer seals and you get a constant flow to the drain. I found what looked like a piece of wood caught in the spacer about 2 weeks ago. Damn if I could figure out how wood got in there.
    Dec 2009
    Alaska
    There are spacers and seals in the valve body and they work with the piston to channel the water to go to the media or to different parts of the cleaning cycle.
    Power head comes off and then the cover plate comes off and the piston and seals and spacers come out of the valve.
    There are 4 spacers and 5 seals, I would say that possibly one of the middle three seals has a challenge and or the piston ..
    Sep 2011
    Utah
    Thanks folks. I think this is beyond my abilities. I just need to find a local expert I can trust.
    -gl
    Sep 2011
    Utah
    Ok, I tested the hardness with one of the cheap Home Depot kits. The hardness came up around 250 parts/million. Again, I have 7 people - 3 of them are teens. My current system is a Fleck 5600se. Do you think it is a good match?
    -gl
    What size resin tank? That will tell you the size of the softener.
    Feb 2011
    NW Ontario, Canada
    I was told you cannot go simply by the size of the tank, that some manufacturers may use the same size tank and use less media and different control valves.
    Sep 2011
    Utah
    Sorry but, I am not sure what the resin tank is. Is it the one where the salt resides or the main tank?
    -gl
  1. Lav draining well but.....
    By export! in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2010, 06:39 AM
  2. tub not draining
    By rrgnjd in forum Drain Cleaning
    Last Post: 10-04-2006, 09:24 AM
  3. tub not draining
    By rrgnjd in forum Shower & bathtub Forum & Blog
  4. Drainage for the washer is continually overflowing...
    By jeremy2323 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-29-2006, 04:52 AM
  5. Continually clogging kitchen faucet
    By raeiken in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-19-2006, 09:31 AM
