Results 1 to 4 of 4
Thread: Commercial water heater output
    DIY Junior Member ferd's Avatar
    Mar 2008
    Talking Commercial water heater output
    If I have a 400,000 btu boiler heating water into a 370 gallon tank and I change the tank out to a 120 gallon tank, how much capacity do I loose? Assuming 95% eff boiler.
    What's your usage rate and temperature? Incoming water temp?
    Mar 2008
    output 130 deg incoming can be down to 40 boiler should put out 500 gph Just wondering what differance the tank will make.
    Plumber jimbo's Avatar
    Quote Originally Posted by ferd View Post
    Round numbers, the boiler heats produces 400 gallons per hour. FIRST hour delivery is the recovery rate ( 400 gallons per hour ) PLUS 70% ot tank. SO your first hour availablilty drops from 660 gallons to 485 gallons. After the first hour, it is all recovery, 400 gallons per hour.
  1. Commercial Plumbing (Restaurant) repair problem--hot water coming out ice and urinal
    By Russ5879 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-06-2010, 01:30 PM
  2. Diverter for shower output OR hand-held output but not both
    By Dgraham in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2009, 07:18 PM
  3. I need to size a commercial hot water heater for my building.
    By Erico in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2008, 01:35 PM
  4. Commercial Water Service Pricing Question...
    By BSA Construction LLC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-18-2007, 05:21 PM
  5. commercial hot water system help
    By perrycat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2007, 07:14 PM
