Results 1 to 8 of 8
Thread: Air Compressor Size for Winterizing
    DIY Member Flipperman2a2w's Avatar
    Feb 2011
    North Carolina
    Default Air Compressor Size for Winterizing
    There have been quite a few posts on compressor sizing to blow out sprinkler system pipes, but I havenít had much luck finding information on compressor size for winterizing a home. . . It seems like a small home would have less piping than a sprinkler system?
    I have a 1200 Sq. Ft. one-story cabin with 2 bedrooms and 2 bathrooms on a private well. The piping in the crawl space is all ĺĒ PEX.
    I would like to purchase an American made air compressor, as Iíve just read horror stories about the cheap ones that can be purchased at Harbor Freight. I guess the old adage is true- you get what you pay for.
    That having been said, most of the American made compressors are BIG. North Star, Ingersoll Rand, Quincy, and Chicago Pneumatic are mostly 20-30 gallon+ units. Those are all fairly expensive and seem like they might be overkill.
    Iím considering the Ingersoll Rand Twin-Stack Air Compressor ó 2 HP, 4-Gallon Capacity, 4.3 CFM @ 90PSI, Model# P1IU-A9 for about $359. This looks to be the smallest unit made by IR, but Iím concerned about the capacity and CFM being great enough for my task. . .
    The next step up is the Ingersoll Rand Garage Mate ó 2 HP, 20-Gallon Capacity, 5.2 CFM@ 90PSI, Model# P1.5IU-A9. This unit is obviously bigger and (consequently) more expensive by about $200.
    Thoughts?
    Feb 2011
    NW Ontario, Canada
    Unless you can utilize a good size bladder tank to build up with air on the water side, you will need the 20 gallon capacity. I have a small 4 gallon tank on my compressor and it's too small for just blowing out my underground lines.
    Feb 2011
    North Carolina
    Thanks so much for the reply. I kind of figured it would probably be too small Looks like I'm going to have to upgrade to the larger model. It seems kind of crazy laying down that kind of cash to ensure that my pipes don't rupture in the cold, but I can't imagine the feeling of turning the well pump on in the summer and hearing the sound of running water under the house. . .
    Given the small volume of the piping in a residence, and the VERY small pressure required to push the water out of the piping, a small 5 gallon compressor is MORE than adequate for the task, especially if it has power and continues to pump even when the tank is almost empty. The real secret, and question, is HOW you go about doing the winterizing.
    Feb 2011
    NW Ontario, Canada
    In my home, all the supply lines after the pressure tank are copper and properly pitched to be able to drain. There are very few spots where small amounts of water may remain. If I first drain all the lines, then close all the stops and pressurize the lines with air, the volume of air in the lines is adequate to blow out the residual.
    Where my compressor comes up short are my outside underground poly pipes since they are not pitched to drain. I have to repeatedly air them up, purge, and air them up again, each time blowing out less and less water.
    Mar 2011
    Long Island, NY
    Same here; my "2 HP " C&H 11 gallon compressor just does not have enough volume to push all the water out of the long run poly pipes to get all the water out in one purge per zone. The closer heads clear first and unless I cap them off, they piss out all the pressure and leave less for the more distant ones. The guys that go around with gas engine driven compressors on their trucks can blow out all the zones on a residential system at once. Looks like 50 gallon tanks on theose trucks. Of course that is overkill for a homeowner, but in my experience, my 11 gallon tank is not an ideal size for this application. It WILL get the job done in 2 or 3 attempts per zone though.
    DIY Junior Member Daveh's Avatar
    Jul 2013
    Idaho
    The local commercial guys usually rent a towable gas or diesel powered air compressor, but thats mostly for time saving as they would want to get the job done quickly as possible.
    A small cabin I would think you would have to blow out & recharge one section at a time using a 1 to 2 hp compressor with a 15 or 20 gallon tank.
    Surprisingly there are still quite a few American compressors companies around...http://usamadeproducts.biz/air-compressors.html
    HandyWOMAN pitterpat's Avatar
    Jun 2005
    Indianapolis
    Why not just rent a compressor when u want to do the job....$50/time cover abt 4 yrs.
  1. Winterizing - other than pipes ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2010, 10:07 PM
  2. What size air compressor is necessary?
    By cpeters in forum Irrigation / Sprinkler Forum
    Last Post: 10-23-2009, 05:10 PM
  3. Winterizing well
    By Elinger in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-28-2008, 06:09 AM
  4. Winterizing question
    By martin1b in forum Irrigation / Sprinkler Forum
    Last Post: 05-24-2007, 08:47 AM
  5. House winterizing
    By frenchie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2007, 07:17 PM
