Results 1 to 2 of 2
Thread: Need help with Carrier Furnace and LP connection
    DIY Junior Member dcorazal's Avatar
    Jul 2011
    Minnesota
    Default Need help with Carrier Furnace and LP connection
    I connected up the wiring from the thermostat and powered up the furnace. Taped interlock switch for the front panel. After studying the wiring diagram I realized that part of the LP conversion kit there is pressure switch added to the furnace so it won't turn on with no gas pressure. I connected up my 20lb gas tank to the furnace to see if it would start and it did.
    I only momentarily let the furnace run not knowing if the gas pressure from a 20 lb gas tank would have enough gas pressure (or to little) to fire the furnace.
    Question: For testing purposes-- can I run the furnace on a 20lb tank? Should I have a regulator on it?
    I think (but am not sure) that you can or maybe already have damaged things in the furnace without having a pressure regulator in line. Now, the furnace itself may have a secondary one and you may be lucky. Typically, there's a regulator on the LP tank before it feeds anything. WIth a bare 20# tank, that is missing.
  1. Carrier 95% Natural Gas Forced Air Furnace
    By sarrowsm in forum HVAC Heating & Cooling
    Last Post: 04-02-2011, 01:54 PM
  2. Carrier humidifier uses too much water
    By OldeEightSouth in forum HVAC Heating & Cooling
    Last Post: 01-13-2011, 07:57 PM
  3. Carrier identification
    By Giles in forum HVAC Heating & Cooling
    Last Post: 10-17-2009, 09:14 AM
  4. What can I do with this carrier?
    By Joerg in forum Toilet Forum discussions
    Last Post: 01-11-2006, 03:39 PM
  5. Wall mount carrier problems
    Last Post: 01-09-2006, 04:33 PM
