Thread: Well and pump input
    DIY Junior Member doug george's Avatar
    Sep 2011
    idaho
    Default Well and pump input
    I'm getting ready to run water to a nearly finished home. Please see updated post
    Moderator valveman's Avatar
    Mar 2006
    Any pump you put in that well is going to need a 2 or 3 GPM Dole valve or ball valve choking it back to keep from pumping the well dry. So you could use the pump you have now, just need to reduce its flow to less than 3 GPM. Or you could use that deep well pump in the cistern to pump water to the house and get a new 5 GPM, 1/2 HP to put in the well. The 1/2 HP AY McDonald you mentioned will not give more than 50 PSI. You need to run at 60/80 to get 70 PSI to the house, since you want 55 PSI and you have 40' rise, which equals 70 PSI. Oh, and you only need a 4.4 gallon pressure tank if you use a CSV.
    Feb 2011
    NW Ontario, Canada
    I would put a submersible with a sleeve into the cistern and protect it with a Cycle Sensor http://cyclestopvalves.com/prod_sensor_geninfo.html or a ESP15/99 http://cyclestopvalves.com/pdf/eps1599_brochure.pdf just in case you you empty the cistern. I agree with the small pressure tank and CSV as Cary suggests.
    Sep 2011
    idaho
    Thanks for the input......
  1. New Construction - DIY looking for Input
    By Twinpeaksr in forum Plumbing Forum Discussion & Blog
    Last Post: 03-16-2010, 10:34 AM
  2. Looking for input on DWV install
    By pa_kettle in forum Plumbing Forum Discussion & Blog
    Last Post: 03-26-2009, 02:19 PM
  3. Ice Maker input?
    By MKB in forum Plumbing Forum Discussion & Blog
    Last Post: 11-03-2007, 05:18 PM
  4. FAU rating- input vs. output?
    By ked in forum HVAC Heating & Cooling
    Last Post: 08-20-2007, 08:45 AM
  5. Using Artesian As Pump Input
    By brianander in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-19-2007, 12:47 PM
