Results 1 to 4 of 4
Thread: What is the ~purpose~ of laundry boxes......
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    Default What is the ~purpose~ of laundry boxes......
    Okay. I currently have 2 small profile valves right behind my laundry machine almost near the height if the machine itself. Easy to turn off as they are 1/4 turn ball valves. Not exposed but ~easy accessiable~. Next to it is a huge cast iron sink that is my laundry sink - that I loop the hose into to drain.
    I've been looking at laundry boxes.....and am curious. The only time I would turn the valve off would be if I went on vacation.
    For those with laundry boxes, aside from it serving as a consolidation point for your washing machine, do you guys turn the valve on/ off each time you use it.
    I need to redo the entire basement so tackling this if I was ....is best done now.
    I turn mine on/off each time I use the WM. Those designed for a WM, often have a single lever to get both at the same time. You do not need a box.
    Yakima WA
    It seems to me the box may be a nice thing to use if your laundry area was in or close to your living area. In a basement where looks may not be quite as important, they serve not useful purpose. Years ago I bought one for my basement laundry area. I use it, but it is just attach to the cement wall. Probably a waste of money, but it seemed like a good idea at the time. I use the single lever shut off, but we really don't turn the water off very often. I suppose after a hose blows we may regret it, but since there is a floor drain directly in front of the washer, it isn't likely to cause too much damage. (I hope)
    After 11 years, I turned my washing machine valves off last year when I got a new machine. Otherwise they stay on all the time. That was with a low top loader and the valves were accessible if I had wanted to use them. With the new front load machines on pedestals, the standard WM box and valves are usually inaccessible for constant on/off operation.
  1. Laundry Boxes - Any custom jobbers ?
    By chefwong in forum Plumbing Forum Discussion & Blog
    Last Post: 09-13-2011, 06:21 AM
  2. A new purpose for man's best friend
    By Cookie in forum Health and Wellness Forum
    Last Post: 04-27-2011, 07:53 PM
  3. What is the purpose of the Controller?
    By rrekih in forum HVAC Heating & Cooling
    Last Post: 11-18-2009, 07:46 PM
  4. Purpose of pressure tank
    By DrewDog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-30-2008, 12:10 PM
  5. Purpose of Platform Under Toilet?
    By boomer70 in forum Toilet Forum discussions
    Last Post: 10-27-2006, 05:58 AM
