Thread: Can I connect PEX directly to water meter in basement? (NJ)
    DIY Junior Member gil716's Avatar
    Sep 2011
    Northern NJ
    Default Can I connect PEX directly to water meter in basement? (NJ)
    Hello, after learning a lot from this forum, I've decided to redo the main trunk in my house with PEX. I heard from a friend's plumber that the New Jersey code does not allow you to connect PEX directly to the water meter. Has anyone ever heard this before? I understand why a water heater needs to have copper, but why the water meter? I assume that I would have to extend the ground from the incoming pipe all the way to my cluster of copper pipes?
    Thanks.
    The only time I have heard of this requirement was when the water meter was outside the house, then they require about 3' of copper from the meter before changing materials. The usual reason being that when the plastic line broke, you did not have to disturb the meter to fix it.
    Sep 2011
    Northern NJ
    Thanks for the quick reply. The meter is inside the house so perhaps he just forgot the part about being outdoors.
    IT could also be a local thing to make your life more difficult, and/or make more work for plumbers.
  1. Where to connect hot water recirculation line at water heater?
    By gplumb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-06-2011, 07:51 AM
  2. Water softener, metal studs, water meter, copper pipes...
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2010, 08:54 PM
  3. Connect house to water heater with PEX?
    By Mikey in forum Solar and Geothermal Water Heating Forum
    Last Post: 02-24-2008, 07:07 PM
  4. Connect house to water heater with PEX?
    By Mikey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Copper Connectors directly to Water Heater Question
    By Munger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2008, 11:19 AM
