Results 1 to 4 of 4
Thread: Ok to put slight bend in 1/2" hard copper pipe?
    DIY Junior Member Spaceball1's Avatar
    Aug 2011
    Twin Cities, Minnesota
    Default Ok to put slight bend in 1/2" hard copper pipe?
    I'm installing a new 1/2" hard copper (blue) line from my utility room to supply water to my fridge.
    Since I'm new at soldering copper, I wanted to figure out a route that would minimize soldered joints inside walls & ceilings. I found a solution that puts a single 45 degree soldered joint that will be accessible in the future (near a bathroom vent/light)
    Here's the thing.. I'm not expecting the 45 degree angle to put me exactly in the location where I'm tapping in to the main supply line. I think it will be close - like 3"-6" - but not exact. So would it be ok for me to gently bend a 4-ish foot length of pipe by enough to make this work?
    I know that you aren't supposed to bend hard copper to make tight corners, but the radius I'm looking at is probably like 40' or more. More of a 'curve' than a 'bend'..
    EDIT: Just to clarify, this new line is from the supply (downstream of water softener) to a new recessed box w/valve in the wall behind the fridge. This is NOT the line from the wall to the fridge.
    Here's a quick sketch to show what I'm talking about..
    Yakima WA
    If you solder an elbow to the pipe you want to bend pointed down, then solder a street elbow into in the line you want, you will not have to bend a pipe. I'd solder the street elbow onto the pipe going to the main supply first. This will make it easier to get the correct line before finalizing the elbow/street elbow connection.
    Aug 2011
    As it turns out, I was able to find a better route with no 45's or bends.
    Yakima WA
    Glad you solved your problem. My solution is usually referred to as a "swing pipe". Very useful when working with PVC irrigation lines.
  1. Is It Okay To Spray "Great Stuff Foam" Around Copper Pipe and Copper Fittings?
    By turbocruiser in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-01-2013, 09:34 PM
  2. Draining Copper Pipe Causes Corrosion? "Old Wives Tale" or ?
    By dayster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2011, 04:51 PM
  3. Replies: 2
    Last Post: 05-04-2010, 03:57 PM
  4. How to solder a "T" in copper pipe?
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2008, 05:29 AM
  5. Male copper adapter to shower valve slight drip?
    By bathwise in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-29-2006, 06:03 AM
