Results 1 to 2 of 2
Thread: Where can I find an over-size surround 64" length replacement for my bathroom?
    DIY Junior Member johnjmcg's Avatar
    Sep 2011
    Westborough, NY
    Default Where can I find an over-size surround 64" length replacement for my bathroom?
    Do any major retailers or manufacturers have surrounds for my 64" tub area. The old one cracked and I need a good PVC type replacement with a few shelves. Thank you. John M from MA
    Tubs are generally sold in 6" increments, rough-opening measured to the studs (not the finished walls), so it is highly unlikely that you have a 64" surround, it is almost certainly a 66" one. These are usually part of the tub, and not an add-on, so often are not available separately. Now, you could have something like a solid-surface one custom made out of Corian, Silestone, etc. any size you want. If your tub model is still being made (unlikely), you might be able to buy a direct replacement for it, but parts costs may be as much as a whole new tub. The alternative would be to possibly tile the area, but it may be less expensive to just replace the tub with a new one and its matching surround.
  1. pipe size /max length of run for kitchen, Canada Code
    By Philbert in forum Canadian Plumbing Code Questions
    Last Post: 07-25-2012, 05:04 PM
  2. What can I use for Sump Pump Liner (Basin, Pit)? Can't find size I want
    By findout001 in forum Plumbing Forum Discussion & Blog
    Last Post: 08-20-2011, 03:54 PM
  3. Oh, dear. Where can I find a European-size faucet aerator???
    By staceyneil in forum Plumbing Forum Discussion & Blog
    Last Post: 03-29-2011, 01:54 PM
  4. I cannot find a replacement!!
    By mastercraft205 in forum Water Heater Forum, Tanks
    Last Post: 11-09-2009, 05:50 AM
  5. Matching pump h.p. to well point size and length?
    By ron in sc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2007, 05:52 AM
