Thread: propane auto changeover two stage regulator on a house...
    DIY Junior Member jrc0210's Avatar
    Sep 2011
    MD
    Default propane auto changeover two stage regulator on a house...
    I have propane (100# tank) that runs my fireplace only and have seen RV's use an auto changeover regulator to attach two 100# tanks so service isn't interrupted, can I set up my house the same way? I would like to add another tank to make life easy when its time to refill the tank. Also would I be able to use (legally) LPG rubber hoses to connect the tanks to the regulator (as done on RV's)? I know rubber deteriates but I figure I would be inspecting it every time I refill the bottle(s) and before every season.
    Thanks in advance
    John
    They usually come as a unit with the changeover valve and two "pigtails" to attach to the tanks.
    Sep 2011
    MD
    Can these units be used on a house or are they just for RVs? Are the rubber "pigtails" an approved way to connect to a rigid house supy line?
    Thanks again
    John
  1. second stage regulators, propane application
    By greyhound1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2010, 09:26 AM
  2. Changing water pressure on house pressure regulator.
    By kskier in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-30-2010, 09:20 AM
  3. Propane line from tank to house?
    By HockeyFan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-16-2008, 06:50 AM
  4. Whole House Auto-Shutoff Valve?
    By Shinshi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-04-2008, 06:15 PM
  5. Propane Pipe Sizing & Regulator placement
    By FredC in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-23-2007, 11:08 AM
