Results 1 to 5 of 5
Thread: shower faucet slowing the water flow (w video)
    DIY Junior Member Eiddie's Avatar
    Sep 2011
    Minnesota
    Default shower faucet slowing the water flow (w video)
    HI
    Why is my shower faucet slowing the flow of the water after a few seconds?
    I took a little 5 second video to show you what I mean - watch how it squeezes back in on it's own. Almost seems like it was designed to do that, but I can't imagine they would design the handle to actually give the customer a worse flow and crappy shower.
    http://www.youtube.com/watch?v=cnotjSKFy1c
    What can be done?thanks!
    Some of the new Moen faucets will do that until they get a little dirty.
    I haven't installed one like that in twenty years. The new ones are all pressure balanced. Is it a new "repair" meaning new cartridge replacement?
    Do you you find an old non-code faucet at a big box store?
    Sep 2011
    Minnesota
    Thanks Terry for the reply, so what you're saying is that this will eventually go away after some use? I had a new moen kit (shower head, faucet, handles, trim ect) that I wanted to have put in, but the plumber who helped me said that would cost a bunch and require a lot of time opening the wall and he said he had a trim for that model in the van so all I'd need to do was put on a new handle. I'm not sure if he changed the cartridge. I can go back and look at the receipt, how much would a new cartridge cost roughly? The handle I got locally at the hardware store. Thanks again.
    I'm sure he installed a new cartridge. Which gives me a warm feeling for him. You now have a "new" faucet, which will after a few days work the way it should.
    If and when you want to open the wall a bit, then you can install one of the new pressure balanced faucets.
    It also sounds like he put some silicon plumber's grease on it (which is good). You could wipe a little off.
  1. Water Flow At Both Faucet & Shower Head
    By jerryb437 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-07-2011, 10:04 AM
  2. Low flow from hot water tub faucet
    By rack04 in forum Shower & bathtub Forum & Blog
    Last Post: 11-29-2010, 05:39 PM
  3. Water flow - Is it the faucet?
    By mds in forum Plumbing Forum Discussion & Blog
    Last Post: 01-26-2009, 09:11 AM
  4. shower faucet back flow problem?
    By mikeprause in forum Shower & bathtub Forum & Blog
    Last Post: 09-16-2008, 07:33 AM
  5. Flush force slowing
    By jaybird in forum Toilet Forum discussions
    Last Post: 05-01-2006, 06:17 AM
