Results 1 to 2 of 2
Thread: Debris Loop for trap primer
    Jun 2009
    Canada
    Default Debris Loop for trap primer
    The trap primer I'm installing requires a "debris loop"...
    As shown here:
    http://www.pppinc.net/common_files/i...d-W-DU-USS.jpg
    If I'm branching off of a vertical piece of 1/2" copper, would it not be redundant?
    I'm thinking T and 1/2" ball valve should be fine, the only way I could see creating the loop is using 3 90s...
    As a practical matter the trap primers do NOT work as effectively as publicized, but in a vertical line, any debris should be dropping to its bottom and none into the trap primer. It is different with a horizontal line where any sediment would be moving along the bottom and would drop into a TP hanging down from the line.
  1. Trap primer installation
    By blitziger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-15-2010, 12:38 AM
  2. Trap Seal Primer
    By BigMonkey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-03-2009, 04:09 PM
  3. P-Trap with Primer
    By chezball in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2009, 07:58 PM
  4. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 08:06 AM
  5. Trap primer questions
    By eagleslawyer in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-26-2005, 03:07 PM
