Results 1 to 8 of 8
Thread: Carbon filter before or after water softener
Hybrid View
    DIY Junior Member Bloom80's Avatar
    Sep 2011
    New York state
    Default Carbon filter before or after water softener
    We have a well and water system. Having problems with poor water pressure. We think the placement/order of the pieces may not be in correct order? Does the carbon filter go before or after the water softener?
    Dec 2009
    Alaska
    If you have any amount of iron in the water I would put the carbon in AFTER the softener.
    If it is hardness and smell then it could go before the softener.
    I assume the filter is a disposable cartridge type and not a backwashed type. Cartridge types if not replace frequently wil cause lower water pressure to the softener and eventual failure of the resin.
    Smell if not H2S gas doesn't harm a softener and if you have enough H2S to harm a softener you should be using a backwashed or regenerated filter.
    So I say cartridge types are the worst choice but should go after the softener if ya just hav'ta have one.
    What about an upflow carbon filter such as these...http://www.ohiopurewater.com/shop/cu...cat=764&page=1
    Do they perform well enough to put before the water softener? It says the SFR is 4-6 gpm on these. Would that have any affect on sizing a water softener?
    IMO if you want to remove chlorine on a whole hose basis, you shouldn't because it is in the water for a couple very good reasons. Remove it as POU, where your use the water instead of POE where the water enters the house,
    Most any house with more than one regular bathroom will want more water than 4 gpm.
    So what are the "couple very good reasons"? just curious. I know there are different shcools of thought on chlorine removal, but I want to hear every side before I make a decision.
    I know one of them is to eliminate waterborne disease, but I just figured that would not be a problem if it was removed at POE as the water doesn't have far to go after the chlorine is removed. Is that short distance in your house enough to pose a problem with manifesting waterborne diseases?
    The two reasons I WANT to remove the cholrine are:
    1. Complaints from the family of the odor and taste. I do not know exactly how much chlorine is in our city water, but it's enough for us to not want to drink the water without going through a carbon filter. I would just put in a RO in the kitchen, but even brushing teeth is a nuisance in the bathrooms with the extra chlorine.
    2. I have heard from many different sources that chlorine will shorten the resin life and in general it is best to remove the chlorine before it enters the water softener as chlorine just tears them up quicker.
    So even with a water softener AFTER the slower carbon filter, I will still only get 4gpm at each faucet in the house? In my mind it seems like it would still fucntion the same in the house until the water softener is emptied out of water, then the flow would be slowed down to 4gpm because it is depending on the filter and maybe cause bleeding of the hard water if the softener can't keep up.
    I'm still learning all of this so please let me know if I'm correct or way off base.
  1. Rebedding a Culligan Carbon Filter / General Water Treatment System Questions
    By scrupul0us in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-11-2011, 08:23 AM
  2. seeking fridge filter without carbon
    By jeremytl in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-15-2011, 09:36 PM
  3. Recommend Water Filter (not softener)
    By Oldcoyote in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-01-2009, 06:13 PM
  4. Iron filter vs. water softener
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2008, 11:25 AM
  5. Whole house carbon filter installation with softener
    By dabiz7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-27-2008, 03:36 PM
