Results 1 to 4 of 4
Thread: How to properly shut off one hot water tank in a parallel system?
    DIY Junior Member joeyw's Avatar
    Sep 2011
    Alberta
    Default How to properly shut off one hot water tank in a parallel system?
    Hi, I have two gas hot water heaters that are setup in parallel and I only need one. I'm just not sure of the proper "step by step" procedure to turn off one of them ?
    Thanks alot,
    Joey
    Jan 2008
    The heaters would likely both last longer if you set the first one to heat to a medium temperature and then the second to your normal "hot" water temp.
    If you shut one down and drain it, it will be likely to corrode quite rapidly. If you leave water in it, it could harbor bacteria.
    If you really want to shut it down, it should be removed from the plumbing system.
    Nov 2008
    Chicago, IL
    That only works if the heaters are in series, in Parallel they need to be set to same temperatures. If you have them set to different temps in a parallel the cooler heater will temper the water from the higher temp heater.
    Now to answer the OP question, you would turn off the water shut off to the heater you want to turn off and turn off the gas to the same heater. Casher_Chick does have one thing right and that is you would be violating the code by creating a dead end fixture and piping. It’s best to remove it completely and remove the piping that would run to the heater that you removed to eliminate any dead ends in the plumbing system.
    A properly installed parallel system would have valves on the inlet AND outlet piping so you could shut both of them to isolate the heater. Once that is done, NOTHING that happens in the heater can impact the rest of the plumbing. Before restoring it to service, the heater would have to be drainded, flushed, and refilled with fresh water. But, other than standby losses, you only heat the water you use, so leaving both heaters in operation will NOT substantially change, if at all, your utility bill.
  1. Replies: 7
    Last Post: 09-02-2011, 06:34 PM
  2. Water Tank Setup - 1-Tank System vs. 2-Tank System vs Tankless
    By Furnace in forum Water Heater Forum, Tanks
    Last Post: 04-27-2011, 06:22 AM
  3. HOW TO PROPERLY Turn on your Sprinkler System
    By greenbaypackersfan in forum Irrigation / Sprinkler Forum
    Last Post: 04-11-2010, 12:37 AM
  4. Toilet tank will not refill properly
    By mdsmeck in forum Toilet Forum discussions
    Last Post: 01-09-2009, 08:51 AM
  5. Water heaters piped in parallel
    By greekguy7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2007, 06:58 AM
