Results 1 to 2 of 2
Thread: Is ths well configuration normal?
    DIY Junior Member dlatzko's Avatar
    Sep 2011
    Newark, Delaware
    Default Is ths well configuration normal?
    Is it normal to have the submersible pump below the casing? Any other comments? Here is what the invoice from my two year old well system says:
    482 ft drilled at rate of $8.50 / ft
    140 of Sch 40 steel casing @ 18.00 / ft
    pressure grout as required
    drive shoe
    1 hp 5 gallon Aermotor Sub Pump
    1 hp control box
    455 ft 10/4 Sub wire
    450 ft of 200 psi pipe
    455 ft rope
    etc...
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by dlatzko View Post
    Yes, if that is where the water is. Depending on the GPM the well produces, all of the water above the pump is storage that allows for more draw between recovery periods.
    $8.50 per foot? It's $48 per foot here.
  1. Please critique this drain configuration!
    By Ryan1978 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-02-2010, 10:27 AM
  2. DWV configuration good?
    By Bobby P in forum Plumbing Forum Discussion & Blog
    Last Post: 01-03-2010, 11:20 PM
  3. Help with trap configuration
    By thebordella in forum Plumbing Forum Discussion & Blog
    Last Post: 11-29-2009, 06:27 PM
  4. Can anyone please ID this weird pipe configuration?
    By manintrees in forum Plumbing Forum Discussion & Blog
    Last Post: 11-06-2009, 03:56 PM
  5. Has anyone seen a drain configuration like this ?
    By Jeff Nolan in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2007, 06:57 AM
