IF the "americast" coating has separated from the tub itself, then it is probably still covered by the "limited lifetime warranty", (assuming it was NOT set on a concrete bed which would have voided the warranty), although you would have to pay to remove and replace the tub. The Americast is a 3 layer process, but A/S says that using a cement bed under it concentrates the heat and can cause "delamination" of the three layers.
