Thread: Toto Drake Drip
    DIY Junior Member l8night's Avatar
    Jul 2007
    Idaho
    Default Toto Drake Drip
    Hi Everyone,
    I have two ADA Toto Drake toilets that my family just loves. I have noticed an interesting drip on one of the toilets though that I thought I would ask the team about. When fluid or solids are added to the bowl, I can hear a distinct drip resonate from the toilet before flushing. The drip does not occur after flushing or while the toilet has been sitting without use. The drip appears to only occur after something has been added to the toilet bowl and before flushing. I am guessing it is water flowing over the edge of the trap dripping down into drain outlet but do not seem to hear the drip on the second toilet. I have no leaks at the base of the toilet or underneath the toilet (checked in the crawlspace to be sure). The valve doesn't leak when the toilet isn't being used and water remains at the standard height in the tank when not used. I don't think it is a problem but a little odd as one toilet does it and the other does not (well not noticeable anyway). Does the team think my assumption is correct? If so, can anything be done to stop it?
    Brett
    I think you're probably right. It may be the riser before the drain pipe makes its curve from vertical to horizontal...one may be longer than the other, or one may be cast iron and the other PVC. Anytime something is added to the bowl (which is generally sitting at max volume), some water must flow out over the weir and down the drain.
    Jul 2007
    Idaho
    Thanks Jim. It was my guess but wasn't sure. I tried simply pouring water into the bowl late yesterday and could get it to occur. I thought the stool may not be level but checked it as well. I will note it but won't worry about it for now and just keep an eye on it. I appreciate your thoughts.
    Brett
  1. Toto Soiree Toilet: Drip, Drip, Drip?
    By Philip in Connecticut in forum Toilet Forum discussions
    Last Post: 11-16-2013, 10:06 PM
  2. TOTO Aquia vs TOTO Drake vs Drake II vs Vespin II
    By Terry in forum Toilet Forum discussions
    Last Post: 07-24-2013, 09:22 PM
  3. Toto Drake: 1.6GPF vs 1.28 GPF - Is 1.28GPF Drake just as good??
    By goshenplumber in forum Toilet Forum discussions
    Last Post: 08-09-2010, 10:53 PM
  4. Toto 1,28 Drake versus Toto 1.6 Eco Drake (same price)
    By JLM in forum Toilet Forum discussions
    Last Post: 07-30-2010, 05:04 PM
  5. Toto Drake Drip Sound
    By crete620 in forum Toilet Forum discussions
    Last Post: 08-01-2008, 09:49 AM
