Thread: multi-choice universal valve
    DIY Junior Member skylark's Avatar
    Sep 2011
    california
    Default multi-choice universal valve
    my distributor sold me a delta universal rough (r10000-unbx) which has a threaded bottom outlet for tub spout.
    i am not using a tub feed, only shower- question: do i need to cap the bottom threaded outlet? thanks alot--
    Water will go to ALL outlets, so you must cap any that are not used.
    Yes, if it did not come with a plug, you do need to plug/cap it. Almost all shower valves are made with tub AND shower outlets so they don't have to differentiate inventory.
    And if it were I, the valve would be installed upside down to give maximum flow to the shower head, but keep the hot water on the proper side when the cartridge is installed, i.e., do NOT install it upside down.
  1. Replies: 6
    Last Post: 06-07-2011, 01:26 PM
  2. Universal rough in valve?
    By Andrew21 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2010, 05:38 PM
  3. Delta Multi Choice Valve
    By markthomas1429 in forum Shower & bathtub Forum & Blog
    Last Post: 02-16-2009, 07:31 PM
  4. Plumbers - Valve Choice for replacement valves.
    By motonutz123 in forum Shower & bathtub Forum & Blog
    Last Post: 07-27-2008, 07:11 AM
  5. multi supply line valve shut off doesn't!
    By treasure37 in forum Remodel Forum & Blog
    Last Post: 01-30-2006, 08:58 PM
