Outdoor Water Supply from Lake
Dave1985
Queens, NY
So I'm looking at buying a house in New Hampshire where the winters get cold. They use water that comes from the lake which is about 30-40 feet away.
they had a buried water line that is crushed and they replaced it with another water line that is on the surface, so obviously it freezes in the winter.
Assuming I can not fix the underground pipe and assuming I do not have enough land to drill a well, what are my options for the pipe above ground?
Insulate it? Use heat tape? Both? and then bury it a little under the ground?
Jimbo
San Diego, CA
In souther NH the freeze line is probably about 42" deep! Insulation does little to keep a pipe from freezing. You could use heat tape, which is an expensive solution. Is this a year round occupancy? If not, figure out how to winterize. If it is year-round, get the pipe installed at the proper depth.
