Page 3 of 3 FirstFirst 123
Results 31 to 38 of 38
Thread: Aluminum Wire
  1. #31
    Jun 2007
    North Carolina
    Hey dude it is not only me but the National Electrical Manufacturers Association that makes these statements as well as the manufacturers of the aluminum wiring methods.
    Your analogy of using copper verses aluminum as a tie wire is nowhere close as to using the two for an electrical circuit. Just how many times do you twist a conductor when making up switches and receptacles? Let me think, well we take them out 3 or 4 times every day to check on them……
    Come on man act like you at least know what we are talking about.
    I suppose if I got me a #8 conductor it would bend easier than a 250kcmil so maybe there is some merit to what you are saying. Any well versed electrician knows that there will be a difference in flexibility of a TW conductor and a THHN conductor but the conductor plays no role but instead the insulation.
    The wire you found in the desert sounds like a piece of wire the Indians used to tie up their electrical cords with. It sure lasted a long time.
  2. #32
    Dec 2009
    northfork, california
    When you wire your house in 12g aluminum wire, be sure and buy all arc fault breakers. That will even out the cost with copper. And install extra smoke detectors, with copper wire, just to be sure.
    The telegraph wire makes great hooks. 120 years in the dirt and the copper is still fresh says much about its qualities.
  3. #33
    Quote Originally Posted by ballvalve View Post
    Arc fault breakers are slowly becoming a code requirement in many more branch circuits, so this won't be an extra (optional) cost. IF you install the stuff properly, it works. That takes both the right technique, materials, and good workmanship.
  4. #34
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    The only comment I have is Beverly Hills Supper Club fire,165 dead and it was blamed on aluminum wiring,but it
    caused a big controversy and lots of law suits.
  5. #35
    Jun 2007
    NY State, USA
    Quote Originally Posted by cwhyu2 View Post
    Why not throw in some pics of burned up bodies, just to add to the drama.
  6. #36
    Jun 2007
    NY State, USA
    I didn't read every word of every post, but I don't recall seeing where anyone said they are going to wire their house with #12AL. Can you point that out to me?
    Or is this just more over dramatics?
  7. #37
    DIY Junior Member jkyu2's Avatar
    Sep 2011
    Quote Originally Posted by Speedy Petey View Post
    I saw the bodies lined up I guess this why Al wiring became such problem.
  8. #38
    Dec 2009
    Our mod said he would wire his house in 12 ga al if he could get it and do it the right way, as I recall.
  1. Aluminum wire and plastic conduit or copper and metal?
    By leejosepho in forum Electrical Forum discussion & Blog
    Last Post: 03-10-2013, 03:34 PM
  2. aluminum supply to sub panel - breaker tripping/wire heating
    By completelyhis in forum Electrical Forum discussion & Blog
    Last Post: 10-11-2010, 11:14 AM
  3. New 220 4 wire stove and old 220 three wire plug
    By Wardsweb in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2010, 05:44 AM
  4. 4 Wire Cable in a 3 Wire Connector Setup
    By chefwong in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2009, 03:17 PM
  5. How to change from 2 wire to 4 wire furnace
    By snuffy47 in forum HVAC Heating & Cooling
    Last Post: 06-04-2009, 05:09 PM
