Results 1 to 4 of 4
Thread: drained hot water tank
    DIY Junior Member William Dyda's Avatar
    Sep 2011
    az
    Default drained hot water tank
    I just drained my hot water tank,after conpletion I have resin from the water softner coming from the laundry tub cold water fauset ,located beside the softner. Help needed. Thanks, Bill
    Dec 2009
    Alaska
    What kind of softener is in question?
    If there is resin going down the drain there are a number of things that could be going on, but the brand and type of softener will help in what could or could not be the reason for resin in the drain line.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Akpsdvan View Post
    If there is resin going down the drain...
    The OP said resin is in the cold supply, not the drain.
    Depending on how the softener is plumbed in relation to the water heater, draining the heater could have reversed the flow through the softener and if it doesn't have a top basket, it could have carried resin into the cold supply line.
    I can think of NOTHING that draining the water heater could have done to cause the softener problem, EXCEPT if the high flow to fill the heater broke the internal distributor in the softener. In any case, the softener MUST be put into bypass mode to avoid having ALL the faucets and toilets plugged with the resin. Then replace the softener or have it repaired.
  1. Air in pipes? Nothing has been opened/drained. Could my Well be running dry?
    By CountryBumkin in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-08-2011, 12:03 PM
  2. Replies: 4
    Last Post: 04-04-2011, 01:45 PM
  3. Electricity power drained
    By batlasi in forum Electrical Forum discussion & Blog
    Last Post: 01-11-2011, 04:39 PM
  4. I drained the system...and NOW I have water hammer????
    By Handymaner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2009, 10:06 AM
  5. Just Drained the cold water tank and pressure is poor after refilling
    By perry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2005, 08:06 PM
