Results 1 to 7 of 7
Thread: Do you have to use a closet bend after a toilet flange?
    DIY Member JoshRountree's Avatar
    Nov 2009
    Fleetwood, NC
    Default Do you have to use a closet bend after a toilet flange?
    If I wanted to go down about 12 inches after the toilet flange to avoid have to cut joists, can I just use a piece of pipe and a coupler into a wye combo?
    Similar to this, but the combo would be on its back for the vertical to horizontal transition.
    When do you have to use a closet bend?
    What's the difference between a spigot bend, and a hub bend?
    Putting the "Y" on its back introduces new dynamics and we would have to know WHAT is happening upstream of the "Y" to determine if, and how, it could be done. A hub bend uses a section of pipe between the bend and the flange. A spigot bend attaches directly to the flange.
    Nov 2009
    Fleetwood, NC
    What if the upstream is just a cleanout?
    Is a spigot bend similar to a street?
    Then it would depend on WHERE, and how, the vent is connnected. It is a "street" fitting but usually, an INCREASING one.
    Nov 2009
    Fleetwood, NC
    Does Lowes carry closet bends? I went yesterday to pick up some stuff for the washer/dryer rough in and I didn't see a single piece labled "closet bend".
    I do NOT buy my plumbing stuff from Lowes, so I cannot answer that question. It may be that their clientele does NOT know what a closet bend is so they would not buy one even if Lowes sold them. Most DIYers, and some plumbers, use elbows and street elbows to make the toilet connection.
    Nov 2009
    Fleetwood, NC
    Streets and elbows just as good? What's the advantages of using closet bends?
    Can you reccommend a plumbing supply place that might be nationally known, or just go to my local building supply?
  1. Street 45/45 closet flange vs. spigot closet bend
    By Noth Jersey in forum Toilet Forum discussions
    Last Post: 12-03-2012, 09:27 PM
  2. Advice / opinion on cast iron flange and closet bend
    By strikebd in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-22-2011, 05:10 PM
  3. Replies: 2
    Last Post: 05-04-2010, 03:57 PM
  4. New Closet Bend and Flange Question
    By Geo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-27-2007, 07:30 PM
  5. Reusing Lead Closet Bend w/ Cast Iron Flange
    By Lakee911 in forum Toilet Forum discussions
    Last Post: 08-23-2005, 12:40 PM
