Results 1 to 14 of 14
Thread: Leaking Delta shower faucet
    DIY Junior Member supercrewdude's Avatar
    Sep 2011
    Default Leaking Delta shower faucet
    Hello everyone. I have a Delta Monitor shower faucet which through searching here I've found is a model 1500. I'm going to post a pic to be sure. It drips slowly and I'm getting ready to sell the house and do not want a leaking faucet. What I need help with is disassembling it to rebuild/replace whatever is necessary to fix it. I removed the handle, the temp. control knob and an 11/16" nut that went onto the white part around the stem. This is where I'm stuck. The chrome assembly there will not move. Am I missing something? Or does it take extreme effort to pull off in order to reveal the parts I need to change. Thanks to anyone that can help. I truly appreciate it.
    This is the fixture:
    And this is where I've run into problems:
    Thank you for your time.
    Plumber jimbo's Avatar
    That nut was holding the cartridge together, and you should not have removed it. You do need to remove the sleeve to access the bonnet nut which hold it all together. WHen you get to that, DO NOT overtorque it. If it does not turn, you want to use heat, or split the bonnet nut with a hacksaw or dremel.
    I have a diagram of the 1500 which I will scan in and post later this evening.
    [url]http://img.photobucket.com/albums/v5...15000001-1.jpg[url]
    Sep 2011
    Thanks for the diagram and reply Jimbo.
    What's getting me is the lower right part of your diagram. Its the section that the handle screws in to. Thats whats not coming off. It seems the sleeve behind it is loose and will come off once the handle section is out of the way. It seems I'm missing something in getting it to come off, or else it's going to take a lot of effort to pull it off. I will put that nut back on. It was easy to come off so it should go back on without a problem....I hope.
    It has been a long time since I have even seen a 1500, but the nut should hold the handle on, NOT keep the cartridge together, and once it is removed the handle pulls off, although it appears that yours needs a little "persuasion". Put the lever back on so you have something for leverage as you wiggle the handle base. Then you remove the cover tube and lock nut before pulling the cartridge out.
    Sep 2011
    Thank you hj for your response. I thought that nut needed to come off but I was not sure. I am going to do what you suggested. I just didn't want to ruin the thing by yanking and prying without hearing from some guys who know!!
    The house was built in 1997 and it's a 2 bath home....but the upstairs fixture isn't the same as the downstairs one....would've expected them to match. Anyway....here's to hoping that it comes off and I can get the parts for it.
    Thanks again to you and jimbo for the help.
    Sep 2011
    Just dropping back to say thank you for the help. A lot of folks get what they need and never come back....but the job is done and much money was saved. So thanks again for helping all of us DIYers with your knowledge.
    DIY Junior Member Jorge Ruiz's Avatar
    Feb 2012
    Milton Freewater, OR
    I have exactly thesame set up, is there supposed to be two o rings and srings or three. it has three paces where there can be o rings. please help
    Feb 2012
    do yuo still have the diagramm of he 1500 delta
    Homeowner
    Jan 2010
    Alabama
    DIY Junior Member PAPACWB's Avatar
    Sep 2012
    Phoenix AZ
    I have this same situation where the sleeve the flow volume control handle is in will not come off. I get from the quote above that it should come of with a little persuasion. As in Supercrewdude's picture, there is quite a bit of corrosion. Should this section slid off leaving the white plastic part (which my guess is part of the cartridge)? I plan on using a conversion kit to change to the 1700 series cartridge. I am just not sure if I should try and pry this off or not. Please help. Anyone. Would much appreciate.
    DIY Junior Member ekammn's Avatar
    Mar 2014
    NH
    Default Issues with Removing Sleeve (?)
    Hello HJ. My issue is similar, but I'm not sure if it's the same model. I cannot get the sleeve (?) off by pulling, wiggling, smacked it a few times with a wrench... when it moves you can hear the left-over water in the pipes making noise in the back (the water is shut off), so I feel like it is still attached somehow and requires a different way to come off... Does that plastic white piece have to come off first? It turn, but it doesn't come off and there is no screw holding it on. If you tell me it just needs a little "persuasion"... then I will keep trying!Thank you for any assistance you can provide! Name:  20140320_132021.jpg
    DIY Junior Member fernie48's Avatar
    Apr 2014
    Alberta
    Hi
    How did you get the sleeve off, with pursuasion, twisting and pulling or does that small metal bar on the right side of the picture need to come off first?
    MJ
    That "metal bar" is the handle attachment. You remove it WITH the piece held by a nut on the center stem.
    Apr 2014
    Alberta
    Thanks HJ
    It worked, thanks for following up.
    Mike
  1. Delta Kitchen Faucet Leaking
    By DonL in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-18-2011, 04:28 PM
  2. Delta 2 handle bath faucet (3555) - leaking from under spout body
    By PeteD in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2010, 08:09 AM
  3. Delta shower temp control handle leaking
    By sbrackin in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2010, 11:00 AM
  4. Repair leaking Delta shower valve
    By marvingreenberg in forum Shower & bathtub Forum & Blog
    Last Post: 03-14-2010, 05:53 PM
  5. Delta Single Handle Shower Faucet - Leaking Profusely
    By wbp3 in forum Shower & bathtub Forum & Blog
    Last Post: 06-09-2008, 07:22 AM
