pump quit while watering garden
bosmom
Missouri
our deep well pump just quit yesterday while watering the garden. we have power to everything. but it has been really dry here. had good pressure before it quit. Any suggestions? Does homeowner's cover wells?
Valveman
Cary Austin
cyclestopvalves.com
If you have power going down the wires to the pump/motor, then it is probably the automatic overload that is tripping. If you wait 15 minutes it should come on by itself. If it is not even trying to come on, you probably don't have the "right" power going down to the motor.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Does the system have a low pressure cut-off and if so have you tried resetting it? If you energize the pump does it draw any current? Have you checked the resistance on the pump leads?
bosmom
Missouri
trouble shooting
How long would it take a professional to trouble shoot the deep well system?
bosmom
Missouri
is it normal to have dirty water after replacing the pump and motor in a well. it will clear up and then get dirty again,
LLigetfa
NW Ontario, Canada
If you upgraded to a higher GPM pump, then it sounds like the well has not been developed to the higher GPM.
