Results 1 to 5 of 5
Thread: Pump short cycling I think?
    DIY Junior Member Rod M1's Avatar
    Mar 2005
    Michigan
    Default Pump short cycling I think?
    I have a Simer 2802E well pump and it's pumping grate at 7 gallons a minute. But when you close the facet it will rapidly and repeatedly cycle on and off.
    Dues that sound like a leak? Would it be on the suction side or presser side?
    Feb 2011
    NW Ontario, Canada
    Sounds like two problems, a busted bladder and a leaky footvalve.
    Mar 2005
    Michigan
    Thanks, "leaky footvalve" You mean a check valve right? This is a shallow well jet pump.
    Feb 2011
    NW Ontario, Canada
    In the pump business there is a distinction between a footvalve and a checkvalve, but they both prevent the reversal of flow.
    http://www.inspectapedia.com/water/Foot_Valves.htm
    Moderator valveman's Avatar
    Mar 2006
    If you have a check valve between the pump and pressure tank, remove it. It will cause the switch to bounce the way you describe it.
  1. Well pump short cycling
    By Eilselc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-22-2011, 08:46 AM
  2. Tank Pressure at Zero, Pump Short Cycling
    By woodworkergal in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-28-2009, 12:58 AM
  3. Pump is short cycling.....Very short!!
    By crittercatcher in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-29-2009, 09:26 AM
  4. Short Cycling Pump - Confused
    By tracyandskye in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-07-2008, 06:54 AM
  5. Irrigation pump short cycling overheating...GGRGGR
    By tombong in forum Irrigation / Sprinkler Forum
    Last Post: 06-15-2008, 07:49 PM
