Results 16 to 30 of 32
Thread: retrofit a water softner to become an iron filter
  1. #16
    Dec 2009
    Alaska
    There needs to be 17" of what is called freeboard or the distance between the media and the top of the tank.
    If the well can do the water then increasing the pins for the back wash would be a good idea, say about 12-14 minutes.
    What color is the cam ? White or Black?
    Did you find the manual for the 2500?
  2. #17
    DIY Junior Member jocko11's Avatar
    Aug 2011
    Indiana
    Should I increase backwash, first group of pins, or rapid rinse, second group of pins? the wheel is black with a white numbered front. What is best time increments for both settings? I have the original book for the maccleens, it has a section on the 2500 in it. factory setting is backwash--3pins, rapid rinse--2pins.
  3. #18
    Dec 2009
    Alaska
    That is the timer wheel that is black, over on the motor that pushes or pulls the piston there is a cam with switches , what color is that??
    I would go to 7 pins and then rapid rinse depends on black or white cam on that motor hooked with the piston.
  4. #19
    Unless the 12" original tank is leaking you should reuse it because it sounds as if it worked well until the valve starting leaking. And I've never heard of a 9" x 41" tank, 9x48" is a 1 cuft. You won't get 2 bags of most anything plus gravel in that size tank, let alone have the proper freeboard (about 15").
  5. #20
    Aug 2011
    Indiana
    Quote Originally Posted by Akpsdvan View Post
    the cam is white.
  6. #21
    Aug 2011
    Indiana
    The unit with the 12" tank originally came for another site, It would foul and need cleaning every five/six months. From the other discussions I suspect the flow was not enough to completely clean the bed. does a smaller tank work better with less flow?
  7. #22
    Remove the drain line and see if there is a restrictor that can be removed or replaced.
  8. #23
    Dec 2009
    Alaska
    The white cam is the older cam, one that had the rapid rinse and brine tank/salt tank refill at the same time.
    The pins and space set up is different than that of the black or now blue cam set up.
    The first pins where back wash and then the spaces where the brine or salt draw along with the slow rinse and then the next pin set was rapid rinse together with the brine refill or salt tank refill.
  9. #24
    Dec 2009
    Alaska
    It is not so much the tank as it is the media that is used.
    If the media needed 6gpm for the back wash but was only getting 4gpm then there where going to be challenges and fouling that would need to be cleaned by hand that would have most likely been done by the water had it had the flow needed to get the job done.
    Some valves will need cleaning no matter the flow, it is the nature of the iron and how it is getting treated to be removed.
    Air injection is the most messy of all the treatment ways.
  10. #25
    Aug 2011
    Indiana
    Should I remove the hydro charger, now that I an using the filox media, or will that enhance the properties of the new media?
  11. #26
    Quote Originally Posted by jocko11 View Post
    A smaller tank requires less gpm to backwash properly but, it also has a lower gpm flow rate to remove the iron from and that means too small and you don't have the SFR (service flow rate) gpm for your peak demand water use and the filter won't work. IOWs the SFR gpm has to equal or exceed your peak demand gpm.
    Doing this stuff on your own is kinda like setting your own broken arm or leg without having the required surgery to git it done right... it usually doesn't work well or for long and creates more problems. Birm may have been a much better choice than MTM etc.. But there are certain things that prevent Birm from being used; like H2S gas and insufficient dissolved oxygen content in the water to be treated, but then it sounds as if you have an air injection part.
    It sounds as if your 2500 is set up as a regenerating filter, not simply as a backwashed filter.
  12. #27
    Aug 2011
    Indiana
    If i use the cabo formula, counting fixtures downstream of the filter ,i get a service flow rate of 7.2. Filox media specs say it is capable for 6gpm service flow per cu ft. Does that mean you have to have slightly more media than 1 cu ft.? Although, the cabo specs.only go down to 7.2.
  13. #28
    I don't know if I'd believe only 7.2 gpm for a normal house.... but yes, you'd need more than 1 cuft of Filox. Like 1.5 or 2 cuft. A 1.5cuft tank is a 10x54, 2 cuft is 12x52.
  14. #29
    Aug 2011
    Indiana
    So i'm going to rebuild the fleck valve and use the old larger tank with the filox. I am ordering another 1/2 cu ft. to make a total 1 1/2 cu ft of media. Is there a benifit to leaving the hydrocharger in place, using the filox media, or should I remove it?
  15. #30
    Does Filox require regenerating or only backwashing? If you have a regenerating 2500 you and do not regenerate Filox, you should change the piston in the 2500 and convert the valve into what is called a flat cap, no injector body or brine valve connection.
    Using 1.5 cuft in a 12" (2.0 cuft) tank probably isn't a good idea because the mineral spreads out and you lose bed depth. That will cause a much lower SFR than you probably need and the filter will fail.
    You also need to know if you have sufficient gpm to properly backwash 1.5-2.0 cuft.
    And do not remove the DLFC (drain line flow control) button as Andy mentioned. Andy (a Kinetico salesman) should stick with Kinetico equipment.
  1. New softner, tank and filter question.
    By John385 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-03-2011, 07:20 AM
  2. softner or filter needed?
    By ugabulldog in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-12-2010, 08:53 AM
  3. What does everyone think of this softner/filter
    By davesnothome in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-17-2009, 07:26 PM
  4. Iron filter vs. water softener
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2008, 11:25 AM
  5. Should I install a whole house filter before water softner?
    By polocash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-29-2005, 08:16 AM
