Seems to me it would be way easier to check it with an angle finder instead of a 1" block attached to a 4 ft. level? A 1/4" block attached to a 1 foot level would work too, but the angle finder seems so easy?
Plumbers are trained to use their torpedo levels and just crack the bubble !
In 30 plus years have never failed a inspection yet
MACPLUMB 777
E-MAIL JERRYMAC@TROJANWORLDWIDE.COM
35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER AND BOILERS SINCE JAN, 1989
281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
Another way would be to use a line level. That is a level with hooks on each end that hook over a stout cord. Drive stakes at each end of the run and measure the distance of the run. This will tell you how much fall is needed for that section. Now stretch the cord from one stake to the next with the high end on top of the beginning point When level is located, tie the cord off and measure down the stake the distance you have determined is needed for the slope.
On most torpedo levels the is a second line which is 1/4" slope.
What is your definition of an "angle finder"? There are many types of "slope/pitchlevels" to give pipes the proper grade.
http://www.digipas.com/DWL-280 Specs.html
Something similar to http://www.amazon.com/Digi-Pas-DWL-2.../dp/B002IQ8W2C
or http://www.amazon.com/iGaging-Digita.../dp/B002LL0BIC
anything to put on top of a pipe to see what angle it is.
BTW, the angle in degrees that I came up with for 1/4" per foot is 1.19348942 degrees, can anyone confirm or deny if that is right?
You'd just plop the digital level on the pipe, look for 1.19 degrees and you're good! The only drawback is it's hard to find one with a degree of accuracy better than 0.2, I'm sure it'd be at least as accurate as a 4 foot bubble level?
