Results 1 to 2 of 2
Thread: Can't get bath sink drain flange to seal
    Default Can't get bath sink drain flange to seal
    Hi,
    One of the white porcelain undermount sinks that came with my granite countertops isn't quite flat enough around the drain flange area. Thus, even after I installed the drain flange with plumbers putty, a few weeks later and most of the putty has washed out in a small 1/2" area around the perimeter of the drain flange. This is allowing the sink to drain even when the stopper is supposed to be sealing it.
    Does anyone have a good suggestion on how to make it seal? The "gap" beneath one part of the flange is probably about 1/16" or less.
    If putty isn't working for you, then you can try Silicone there. It's rather permanent though.
  1. need help with bathroom sink and bath tub drain and vent
    By davidjp3 in forum Remodel Forum & Blog
    Last Post: 05-08-2010, 08:15 PM
  2. Best Kitchen Sink Drain Flange
    By FJK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-18-2009, 10:10 AM
  3. Slow bath sink drain
    By Howard6131 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-20-2007, 10:12 AM
  4. Strange bath sink drain plumbing
    By chadzeilenga in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2006, 03:36 AM
  5. How to seal an overflow hole in a sink drain?
    By mmc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-13-2005, 09:13 PM
