If you don’t care whether you sell it or not, don’t tighten it. If you really want to sell it, get a licensed plumber.
Hello:
I am currently selling my house. The inspector came this week and one of the things he stated to the prospective buyers, is that the toilets needed tightened down. They in turn want it fixed by a licensed plumber.
I went in to check both of them. I have never had any issues with leaking, and I can not get either of them to budge. I basically can not see where he thinks this toilet is loose at.
I have already responded to the buyers with my offer to repair, so how do I know what to look for since he saw something I did not.
Don't pay someone to do a job fast, when you can do a half-fast job yourself.
The bowl needs to be firmly attached to the floor.
Some tanks will have some movement. There's not a lot you can do about that. The inspector may be over thinking things.
On a two piece, you have the tank/bowl junction that might be loose, but not leak. That's easy...tighen the nuts, a little one each side alternately until the tank can't move (don't overtighten - porcelain isn't really elastic!).
Then, you have the bowl to the toilet flange...this is also easy to tighten, again, don't overdo it or you'll crack the toilet. But, on some flooring, regardless of how tight you try to tighten those, the toilet can move if pushed sideways (at least a little). Many codes require you to use caulk around the edge of the bowl against the floor. This does two things: anchors it so it doesn't move, and prevents spills or misses from leaking underneath where they can't be cleaned up without removing the toilet.
Neither of those should require a licensed plumber to fix...Both could result in breaking the toilet if you get overzealous. Neither should take more than a few minutes to resolve.
Ask for an explanation of WHAT is loose, if you cannot move the toilets. I have had inspection reports that had "ambiguous" items which I could not find out what the problem was, and when the homeowner asked, the situation went away.
Thanks Terry for the reply. After Googling the problem, it brought me back to a post on here. I figured out the rock was front to back and found a reply you had given earlier to someone else with this problem and suggested using the plastic shims. Fixed it right up. I appreciate the response and taking the time to give me a straight forward answer.
hj - I think that was the issue with this inspector, however, I did finally find there was a small looseness from front to back.
All toilets must be firm, they can't rock or you'll break the wax seal. If it did rock, just shimming isn't enough, you need to pull the toilet, shim, then reinstall with a new wax ring...wax isn't elastic...it rarely maintains the seal if a toilet is rocking. Doesn't mean it will leak liquids (unless the pipe gets clogged), but it could leak sewer gas.
