Results 1 to 8 of 8
Thread: Add iron out/rust out to Neutralizer?
Hybrid View
    DIY Junior Member kg2k's Avatar
    Jan 2011
    Northern NY
    Default Add iron out/rust out to Neutralizer?
    I haven't seen this addressed and I did search. I have an acid neutralizer. After I installed it I was amazed by how it reduced the red staining in the toilets and fixtures to almost non-existent. It's been a few months now and the staining is back almost to where it was. I see that people add rustout/iron out to water softeners. Is that something that I could do for my AN before a backwash? Is there any reason in particular not to do something like that?
    I'm not sure that will fix the issue but I figured it might be worth a shot to add a cup full before a manual backwash every few months.
    Dec 2009
    Alaska
    Has the unit been backwashing?
    Jan 2011
    Northern NY
    Yes, I manually backwash it but have never gone more than a week without backwashing. Lately been doing twice a week.
    Dec 2009
    Alaska
    If it is a timer set up , it should be every 3 days.
    If it is a manual how much time are you spending on each part of the backwash?
    backwash for ?
    rapid rinse for ?
    How long has the system been in?
    What is the ph of the water?
    How many in the house?
    Jan 2011
    Northern NY
    Quote Originally Posted by Akpsdvan View Post
    backwash for ?
    rapid rinse for ?
    I just click the dial over and let it do it's thing. Never timed it. Ph was like 7.5 last time I tested it. Just me in the house.
    You can't add the Iron Out during backwash unless you did it manually out of a disposable cartridge housing on the inlet water line because the water flow is UP through the media and Service is downflow but...
    You have loaded up the mineral with rust particles by not backwashing more frequently (max 3 days) and that is why you are getting the staining now. Put it in backwash and once started unplug the control for like 15-20 minutes. Watch your well doesn't go dry, then plug it in and let it finish on its own watching for the well to go dry.
  1. Rust spots on new Kohler Memiors cast iron tub
    By jzzz in forum Shower & bathtub Forum & Blog
    Last Post: 10-13-2011, 03:28 PM
  2. acid neutralizer
    By devans175 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-19-2010, 08:05 AM
  3. problem with ph neutralizer
    By tfasbind in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-05-2010, 05:34 PM
  4. Neutralizer backwash HELP.
    By 1krzqb in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-27-2009, 07:16 AM
  5. PH Neutralizer
    By Dan_Cef in forum Plumbing Forum Discussion & Blog
    Last Post: 06-22-2009, 09:51 PM
