Results 1 to 2 of 2
Thread: Showerhead prssure is much lower after returning from vacation
    Creekpaddler Creekpaddler's Avatar
    Aug 2011
    Duck River, TN
    Default Showerhead prssure is much lower after returning from vacation
    As soon as we returned from an 8-day vacation last month, I noticed a substantial drop in showerhead water pressure. It's been like that ever since. And there seems to be a much longer delay between the times when the well pump kicks in to boost the pressure than before the vacation. Our other water fixtures do not appear to be affected as much.
    The incoming water pressure is unchanged: about 35 psi coming into the pressure tank from the well, which has a 3/4 hp submersible pump. No water leaks are visible under the tank or under the 50-gallon electric water heater. I haven't checked the pressure of the tank yet. The iron-filtration system appears to be working normally (when it gets plugged up it can cause problems). It is connected downline from the pressure tank.
    The pressure tank is more than 11 years old. But before I can determine that to be the problem, I need to learn more about it.
    Question: Why would the showerhead pressure drop so much during several days of nonuse? And what should I be looking at for clues to solve this problem?
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Creekpaddler View Post
    The iron-filtration system appears to be working normally...
    My guess is that you are premature in eliminating it as the culprit. Also, it's not about the static PSI, but rather about the PSI you get after a flow restriction such as a plugged up iron filter or piping.
  1. Water Returning to Pit through Air Lock Relief Hole
    By Cooper's Dad in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-20-2011, 08:40 AM
  2. No water returning to toilet
    By Jimbo2 in forum Toilet Forum discussions
    Last Post: 12-07-2007, 09:21 AM
  3. Bathroom torn up and wife returning from vacation!! HELP!
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2006, 12:38 PM
  4. Vacation
    By ally68 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2005, 03:24 PM
  5. New sink is lower...need to lower drain?
    By plumbbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2004, 02:23 PM
