Results 1 to 2 of 2
Thread: PEX Line Size?
    DIY Junior Member jones6826's Avatar
    Dec 2010
    Tulsa, OK
    Question PEX Line Size?
    I feel a little stupid asking this but it always confuses me. Hoping someone can spell it out for me.
    Im trying to run a line from my water heater to my refrigerator thru the attic using pex line. I plan to tee off of the line going into the water heater, its NPT, into a water filter that has push to connect fittings molded into the housing. The hose into the filter measures 3/8 OD. Is this inch line and fittings or do I need to use 3/8 line and fittings?
    The line in to the refrigerator measures OD. What size tube is this?
    I appreciate any help you could give me
    Shannon
    For the 3/8" OD line, you will need a shutoff with 3/8" OD compression outlet; the incoming can be 1/2".
    From the 3/4" line, you will need a 3/4" by 1/2" tee for that.
    The icemaker line is 1/4" OD
    They make shutoffs with 1/4" compression outlets.
  1. Supply Line to Tank Size
    By Designie in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-16-2010, 06:23 AM
  2. Hot water line size
    By keydash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2010, 08:48 AM
  3. what size sewer line???
    By bradl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2006, 01:00 PM
  4. Supply line size
    By Clem in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2005, 06:49 AM
  5. Sewer line pipe size
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-07-2005, 02:16 PM
