Results 1 to 2 of 2
Thread: Adding Kitchenette to basement with drain above floor
    DIY Junior Member stonejohn9's Avatar
    Aug 2011
    Vancouver, WA
    Default Adding Kitchenette to basement with drain above floor
    Hi there,
    I've been lurking on the forums for awhile now without registering and haven't been able to figure out how I'm going to be able to do what I want. The sewer drain goes out of the basement wall about 4 feet up from the basement floor. I want to add a kitchenette, so basically just a sink, to the basement for convenience but how would I set it up to drain? Do I have to put in an ejector pump set up for just a sink or is there an alternative that would work?
    Here's the layout that I was thinking. Obviously, black = walls.
    Here's how the drain currently looks.
    The drain connector here comes from the upstairs kitchen sink. Which I'm planning on using the vent from that sink for the new sink in the basement.
    Thanks,
    John
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    You could use an under sink pump,if it is for limited use.
    www.hartell.com LTA is one to search for on the site.
  1. Laundry tub draining into basement floor drain - open pipe into drain hole
    By scott.oneill in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-24-2010, 02:20 PM
  2. basement - moving toilet drain and adding shower
    By moveright in forum Shower & bathtub Forum & Blog
    Last Post: 12-01-2009, 03:41 PM
  3. Floor drain in basement
    By vholbert in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2006, 06:40 AM
  4. Adding Shower drain in Basement
    By finesstan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-01-2006, 07:32 AM
  5. adding floor drain for second floor laundry room
    By illinipdx in forum Remodel Forum & Blog
    Last Post: 01-12-2005, 08:51 PM
