Thread: The best foam for under a bath tub.
    Default The best foam for under a bath tub.
    Always a good question.
    For those of you plumbers that are using expanding foam under tubs, what is the best?
    American Standard Americast tubs sometimes need something underneath to prevent the creaking and the squeaking. Some people use mortar too. I don't know if A/S is into mortar though.
    My personal preference is mortar, but if you don't have access for that, then sometimes using a foam can with tubing can be useful.
    Jun 2009
    Canada
    I have a 2 piece from MAAX and they recommend a bed of mortar with a 2mil sheet of poly over it...
    I'm interested to hear what everyone has to say...
    In the Trades markore's Avatar
    Oct 2013
    North Pole
    Default How many pounds of mortar?
    BUMP. I have heard not to use window/door or latex based foams because they crumble. Big Gaps expands too much... so that leaves the "regular" gaps and cracks. What is the most and least number of cans used before to achieve success?
    Regulars! : How many pounds of deck mud / mortar / sand mix / hot plaster do you pour into your plastic sheeting sandwich under a 60 inch tub? This is poll-worthy since using too much mud can make it difficult to level the deck.
    You don't level the deck with mortar.
    You put a few piles under the tub, and the tub squishes the piles down.
    I tried to pull a tub that had been foamed in the other day. We couldn't budge it.
    This tub is there forever. I pitty the poor person that has to remove the tub to work on the pump at the far end.
  1. ABS foam core or solid ?
    By PeteB in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-04-2009, 10:22 AM
  2. Expanding foam around pipes
    By Blumengarten in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2009, 06:04 PM
  3. Tub Insulation - Foam
    By jgrimes227 in forum Shower & bathtub Forum & Blog
    Last Post: 01-23-2008, 11:59 PM
  4. foam pipe insulation
    By gfe76 in forum HVAC Heating & Cooling
    Last Post: 11-08-2007, 01:54 PM
  5. Foam blocks under whirlpool tub
    By Laneman in forum Shower & bathtub Forum & Blog
    Last Post: 01-12-2007, 12:34 PM
