Contact Preferred Pumps in Houston http://www.preferredpump.com/houston.html. I'm sure they can assist you.
The minimum pressure release valve on my home water well tank is bad. I am having a lot of trouble finding the part to replace it in Houston Tx. I am looking for Part Number 191-809R which is just the Minimum Pressure Release Valve. It is screwed into the Johnson Controls Part Number F93B-1 Air Volume Control. Does anyone know of a supplier in Houston where I can buy just the Minimum Pressure Release Valve? Can just the valve be replaced or will I have to replace the whole air volume control assembly?
Thanks in Advance,
Keith R.
Porky Cutter, MGWC
(Master Ground Water Consultant)
And replace the whole AVC. The float is probably broken off in the tank anyway.
I doubt preferred would deal with the general public. If anything, try Gulf South Supply on Airline drive. And replace the whole float, the F93B. It's an air release, not a pressure release.
