Results 1 to 3 of 3
Thread: cold water going into the hot water line when tank disconnected
    DIY Junior Member wombat's Avatar
    Aug 2011
    Bellevue WA
    Default cold water going into the hot water line when tank disconnected
    I'm in the process of putting in a new water heater so I have my hot water tank completely removed.
    Now when I run the cold water in my sink, I am seeing some water come out of the hot water intake line. Additionally, now some cold water will out of the hot water taps if I open them.
    Does this indicate some problem with the hot water getting into the cold line?
    You need to finish the replacement is all.
    You are turning on both the hot AND cold faucets, which causes the water to backflow into the hot pipes. Connect the heater, but stop using the faucets until you are done.
  1. warm water from cold water line
    By truckeebirdie in forum Plumbing Forum Discussion & Blog
    Last Post: 08-10-2010, 01:58 PM
  2. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum Discussion & Blog
    Last Post: 09-17-2009, 09:58 AM
  3. cold water line shaking when tub fills?
    By roadk in forum Plumbing Forum Discussion & Blog
    Last Post: 08-28-2009, 06:29 AM
  4. Cold Water getting into Hot Water Line... Help!
    By jrrl in forum Plumbing Forum Discussion & Blog
    Last Post: 02-10-2008, 03:56 AM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum Discussion & Blog
    Last Post: 10-12-2004, 06:20 AM
