Thread: Add bathtub - second floor remodel
    DIY Junior Member beniciaDIY's Avatar
    Aug 2011
    East Bay , CA
    Default Add bathtub - second floor remodel
    Looking to add bathtub in second floor remodel. I have access to 1.5 inch horizontal shower drain line (approx. 4 ft from proposed bathtub drain) in the floor that empties into 2" vertical drain in the wall (approx. 7 ft from proposed tube drain), the main soil stack is also in the wall on this side of the bathroom. On the opposite side of the bathroom, I have a vertical 1.5 inch line, what I assume is a vent line from the downstairs bath that exits separately from the main stack through the roof in the opposite wall (approx. 2 ft from the proposed new tube drain).
    My question is to which line do I connect the new bathtub drain? Can I drain and vent to the closest vent line from downstairs? Can I wye into the existing shower drain and use the closer vent pipe to vent? Or do I need to drain to the vertical pipe above or below the shower line and vent to the closer vent pipe? None of the above?
    You CANNOT connect to the downstairs vent, and SHOULD not connect to the shower drain line. You CAN connect to the vertical drain line, if you do it correctly.
    Aug 2011
    East Bay , CA
    hj,
    Thanks. Figured it had to be the hardest option. As the horizontal run is close to 7 ft ad I need 1/4 inch per ft slope, I assume I cannot use the 2 inch vertical that the shower is using and have to tie into the 3 inch soil stack?
  1. Leak from 2nd floor bathtub through ceiling
    By krowton1 in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2009, 07:47 AM
  2. Floor or bathtub first
    By T_Hartigan in forum Shower & bathtub Forum & Blog
    Last Post: 05-27-2009, 08:45 PM
  3. 1st Floor Bathroom remodel
    By K2 in forum Remodel Forum & Blog
    Last Post: 10-12-2008, 06:18 AM
  4. Closet Flange with remodel floor
    By Mongo in forum Toilet Forum discussions
    Last Post: 12-06-2006, 03:33 PM
  5. Dealing with toilet floor flange in remodel
    By wwilson1 in forum Toilet Forum discussions
    Last Post: 04-30-2005, 07:07 PM
