Results 1 to 11 of 11
Thread: Basement bath/laundry
    DIY Member Kestrel's Avatar
    Aug 2011
    Seattle
    Default Basement bath/laundry
    Hello again wise plumbers...
    As I've posted recently, I'm in the starting stages of a basement remodel, to include a new bathroom. To do so requires an ejector, and some other concrete cracking/excavation - for the toilet and shower, at least.
    In an effort to minimize the concrete work, the following struck me: Can I have a shower and laundry next to each other; the shower with a 2" trap, and its own vent in the wall bounding the shower, and the laundry with a 2" standpipe and trap, and its own vent, with the drainage of the laundry then flowing via a santee into the vent pipe of the shower?
    Like this:
    Nov 2010
    Maine
    No you can not.
    Aug 2011
    Seattle
    Drat.
    Is that because the laundry hook-up makes the shower a wet vent?
    Aug 2011
    Seattle
    Would this work?
    It's not technically a wet vent (as I understand it), that's where multiple fixtures are attached to the same drain line that may only have one vent. On your proposed situation, the only vent is being asked to be a drain...not the same thing. Once a vent becomes a vent, it must always remain a vent - you can't use it as a drain.
    Jun 2009
    Canada
    You've already made it easy by deciding to have the laundry close to the bathroom, now don't make it hard by trying to use a vent as a drain.
    You're going to have to remove concrete no matter what, why not do it all once and do it right?
    Nov 2010
    Maine
    Your 2nd drawing will work and meet code.
    Aug 2011
    Seattle
    Thanks everyone - expert advice much appreciated.
    The other day I posted a diagram that was generally well received, including wet venting a lav into the toilet drain. A detail of that drawing is below.
    I'm trying to understand - it's OK to take a lav drain and drop it down the toilet's vent, but not to do the analogous and drop the laundry's drain down the shower's vent? Is that correct? Is it because the lav/toilet/shower are all a 'group' that are allowed to wet vent together, and this excludes the laundry?
    NO! It is because the washer is a "high volume and flow" device, and its water going past the shower drain connection, WITHOUT a vent, could aspirate the water from the shower trap. It would NOT be vented, because you have the shower vent occulded by the water flowing from the washer. IF you could do it, you would NOT need the washing machine vent in the first place. I have one customer who has a "high flow" device connected to his toilet's vent, apparently because it was the "easiest" place to connect it, and every time water discharges it sucks all the water out of the toilet.
    Jun 2009
    Canada
    Why you keep insisting on using the vents as drains?
    Aug 2011
    Seattle
    I'm not insisting on anything - I'm just trying to learn.
    I suppose I come up with some of these strategies because I don't like concrete work, and I'm trying to minimize it. It's dusty and dirty, the debris is heavy - I just don't enjoy doing it as much as framing or running pipe or installing windows. I was looking for the design scheme for this bathroom that would allow the least amount of concrete break-up and refilling, that's all.
    It also seems that using vents for drains - like the lav into the toilet - was OK. I didn't know how far this extended. I totally understand now about the high flow nature of the original scheme above not being a good or workable idea.
  1. Bath + Laundry Layout Feedback
    By dcp143 in forum Plumbing Forum Discussion & Blog
    Last Post: 11-15-2012, 12:03 PM
  2. Laundry/bath on slab - drainage
    By dwhiteykc in forum Plumbing Forum Discussion & Blog
    Last Post: 04-03-2011, 07:02 PM
  3. Bath + Laundry Layout Feedback
    Last Post: 10-26-2010, 06:19 AM
  4. swap laundry room to half bath
    By tonyf3 in forum Remodel Forum & Blog
    Last Post: 09-10-2008, 08:49 PM
  5. Add Shower to 1/2 Bath / Laundry Room
    By tromo in forum Shower & bathtub Forum & Blog
    Last Post: 11-21-2006, 11:04 AM
