Results 1 to 13 of 13
Thread: Sutdor Vent for powder room
    DIY Member kezug's Avatar
    Feb 2007
    Indiana
    Default Sutdor Vent for powder room
    I am finishing a powder room (sink and toilet only) that already has the piping in the ground for the toilet and right behind the toilet coming up the wall is a 2" line coming up about 4 feet and its capped off.
    I am assuming that this 2" PVC behind the toilet is for venting AND for my sink drain? So I am thinking that I would connect the sink drain to it using a Sanitary Tee for the waste to go down and going up the Tee would be a connection to a Studor Vent.
    Is this how I should be planning this?
    If so, what size would I use for the actual sink drain? (1.5")
    NOTE: that 2" pvc coming out of the ground has no where to go up through the first and second floor on out to the roof like a normal vent.
    Nov 2010
    Maine
    First off I don't think you should "assume" anything. You need to know for sure where that 2" pipe goes and moreover, how and where it is connected. As for the studor vent, you live in Illinois where I believe the code does not allow them.
    Feb 2007
    Indiana
    Actually, I live in Indiana...just corrected my profile as I am not sure why it was listed as Illinois. Good point on the 2" and what it may or may not be...I will dig up some old photos to see if I have a pic before the cement was poured
    Feb 2007
    Indiana
    I found a pic...does this provide enough detail as to what that 2" pipe is for?
    The toilet inlet is right next to the ladder and just to the right of that is the 2" that I described above as being behind the toilet (its behind as the way I am putting the toilet in.
    Aug 2009
    South*East
    It looks like it is a vent for the toilet but if you use a sutdor vent it has to be accessible.
    John
    I find it incomprehensible that if they put in piping for a basement bathroom that they did NOT provide a vent connection at the ceiling since they would have known you needed it. AND, it would have been a simple process to install it when the building was constructed.
    Nov 2010
    Maine
    that looks like a drain for the lav to me but depending on how it was piped below it could also be used as a wet vent. If you are under the IPC then chances are good that you don't need to worry about venting the toilet as long as it is connected to a line that's vented somewhere in the house and I'm pretty sure it is.
    Feb 2007
    Indiana
    As do I, I was young when they built and I am upset that I failed to recognize this during the building process. However, I am more upset that it passed inspection and even more upset that my builder didnt catch it.
    An AAV (Studor is one brand) cannot be the only vent in a system, you need an atmospheric vent also somewhere on that system.
    Feb 2007
    Indiana
    Ok, I have a better picture of what my basement looked like before the cement was poured. I also put in some labels of the pipes that are in the pic.
    My questions
    1) Can I put a studor vent on the questionable pipe? If so, how high should the studor vent be? (NOTE: this will be in an open room as its inside my furnace room)
    2) Can I tie my sink drain waste into the same questionable pipe but below the studor vent?
    Feb 2007
    Indiana
    I am hoping someone can chime in and lead some advise being that I provided some more detail (perhaps all that was mentioned above apply but this picture shows more detail).
    Nov 2010
    Maine
    Sure you can put an AAV on the pipe ut whether ir not it vents anything is another question altogether.
    Feb 2007
    Indiana
    Thanks. But what about my other questions?
  1. Powder Room Toilet
    By DownTheDrain in forum Toilet Forum discussions
    Last Post: 05-31-2011, 10:54 PM
  2. need help with powder room rough-in
    By twashington in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2009, 12:57 PM
  3. Powder room plumbing
    By Zach in forum Remodel Forum & Blog
    Last Post: 07-31-2007, 07:21 PM
  4. Powder Room Venting?
    By sandyman720 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 04:32 PM
  5. Powder Room SMELLS!
    By Sincraft in forum Toilet Forum discussions
    Last Post: 09-04-2006, 11:13 AM
