Results 1 to 2 of 2
Thread: Tiled shower leaking in basement
    DIY Junior Member antbrady's Avatar
    Aug 2011
    Herriman, UT
    Default Tiled shower leaking in basement
    I have a fully tiled shower that has been leaking to the basement underneath. Any suggestions on where to even start to get it fixed? It is in the corner of the bathroom, we've stopped using it completely. In addition, the glass door will not close properly any longer...
    Thank you for any help you can give me.
    Home built 2006.
    Alicia
    Elininate the easy things first: take the trim off of the shower control valve and then turn it on to look and see if there's any water behind the wall coming from the valve. Do the same thing at the shower arm. If it is there, you'd normally see it dripping down past the valve once you have the trim off.
    Are there any niches or benches in the shower? If there are, take a bucket and pour some water in there and see if that isolates the leak.
    But, first, you could take the drain cover off, if you don't have a drain plug, you can use a rubber balloon, and inflate it inside of the drain. Then, fill the pan up to just below the curb and let it sit. See if it leaks out from there. Let the water sit overnight to see if the level drops and you notice if it is leaking visually. If you do this without running any water in the shower, and it leaks, you know it is the pan rather than a leak somewhere in the walls or from the supply. It can be tricky blowing up a balloon at the floor while standing on your head! They do make plugs specifically designed for this, but a balloon is cheap and will work if you get it in far enough.
    Unfortuneately, there are lots of showers built incorrectly. If you're lucky, it may just be in the valve behind the wall, and you might be able to fix that without tearing up much of anything. If you're really lucky, it is that and you can access that wall from the other, non-tiled surface which is generally a lot easier to repair than the tile itself.
  1. condensation/leaking around base of Vikrell shower pan in basement
    By greyconman in forum Shower & bathtub Forum & Blog
    Last Post: 11-18-2009, 08:36 PM
  2. Help! Tiled shower drain leaking
    By FlashPD in forum Shower & bathtub Forum & Blog
    Last Post: 06-13-2007, 04:45 PM
  3. leaking tiled shower
    By jjdeluca in forum Shower & bathtub Forum & Blog
    Last Post: 05-10-2007, 04:26 PM
  4. Bathroom tub/shower leaking into basement
    By sharrison in forum Shower & bathtub Forum & Blog
    Last Post: 06-09-2006, 09:57 AM
  5. Crack in shower pan leaking water into basement! :eek:
    By hiyasam in forum Shower & bathtub Forum & Blog
    Last Post: 10-02-2005, 11:08 AM
