Results 1 to 5 of 5
Thread: Gap at Tile/Tub
    DIY Junior Member catphoto's Avatar
    Aug 2011
    Kenmore, WA
    Default Gap at Tile/Tub
    I just had tile put in my tub/shower enclosure by a tile person. I agreed to put in the grout and the caulk. There is a 1/8" gap between the tile and the tub on the back wall but on the side walls, the tile comes all the way down to the tub. I know 1/8" gap is standard. Can I hear some opinions if having no gap will be a problem or if it will be, how do I cut a gap without ruining the tile? I want to make my decision before I start the grout. Thank you.
    Can you post a photo?
    800 pixels or less.
    Aug 2011
    Kenmore, WA
    Terry,
    Tried to do a photo. 800 pixels is too small to see.
    But it is 4X4 Daltile - sitting right on the tub. I also noticed that at the vertical corners, some tile have a gap between them and some are butted up right next to each other with no room for grout.
    Any ideas.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    In the past we used to caulk where tub meets tile and in the corners and not grout even if there were gaps from
    one wall to the other.There are caulks made for this application.
    Grout is a poor filler around the tub. It does NOT bond to the bathtub, and thus can create cracks. Use a good caulking material, "tub and tile adhesive" caulking is a good one.
  1. Tile over tile in a shower
    By Tobyluke in forum Shower & bathtub Forum & Blog
    Last Post: 02-22-2011, 02:43 PM
  2. Tile patterns with different thickness of tile
    By Searider in forum Remodel Forum & Blog
    Last Post: 11-20-2010, 10:45 AM
  3. Ceramic Tile - thinset and tile gaps
    By justanotherdriftwood in forum Remodel Forum & Blog
    Last Post: 03-13-2009, 04:06 PM
  4. can i tile over tile in a stand up shower
    By stephnej in forum Shower & bathtub Forum & Blog
    Last Post: 01-25-2009, 05:55 PM
