Culligan Mark 812
MrGeminiMN
Minnesota
Hello, I have Culligan Mark 812 which continuously regenerates it is half full of salt which appears not to go down, the drain hose I guess it it's called, continuously drains water. I have unplugged the unit from the power source and by passed the water softener just to get it to stop regenerating. not sure what to do or look for. I live intown so have city water. Please help. Can't afford to replace at this time. Thank You in advance.
Akpsdvan
Alaska
Sounds like a salt bridge and that can be broken so that the salt drops down.
MrGeminiMN
Minnesota
what is a salt bridge and how would I clear it. so far I have cleaned the plastic rod that has a floater on it that is in the salt bin.
Akpsdvan
Alaska
The salt bridge is when the salt gets wet and then dries and forms a crust.... all the salt below the crust is removed as water comes in and then back out again as brine.. the crust is hard enough to hold the salt that is above it from falling down into the hole.
You will need a strong metal pipe of some form and a hammer to bound down through that crust and brake it up some so that the salt above can move down into that hole.
The other way is to remove the salt that you can til you can not remove any more because you have found the crust and then brake that crust.
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
I'm not familair with Culligan but would it get stuck on a backwash or rinse cycle and flow to the drain because of a salt bridge? It just doesn't seem like it should.
Akpsdvan
Alaska
My bad, I fixed on the wrong part....opps.
Mark 812 has a weak spot, that is under the motor where the piston is pulled out and pushed in. There is a white link between the motor shaft and the piston that likes to break, the challenge is getting ones hands on the part... culligan changed the setup to a tray where that link is at... and that also changed the piston.
