Results 1 to 10 of 10
Thread: Where to buy lever for Toto toilet? THU004 and THU068
    DIY Junior Member NullPointerException's Avatar
    Feb 2006
    District of Columbia
    Default Where to buy lever for Toto toilet? THU004 and THU068
    We have a Toto toilet. Recently, while adjusting something else, I managed to snap off the end of the lever at the point where the hole is that the chain goes through. Until I get a new lever, I've duct taped the chain to the lever. Duct tape saves the day again.
    I've tried several levers from the orange and blue boxes with no success. From looking online, it appears I have to buy a special lever and handle that is compatible with my type of Toto toilet.
    Here is a link to a picture of the inside of the tank:
    I'm wondering what type of Toto I have and where I can buy a replacement lever. I didn't see any model names on the toilet anywhere. It says "Toto" and "1.6 Gpf" as you can see in the picture. I've seen some Toto levers online, but I'm not sure if they are the right type. I was surprised at how expensive they were in some cases (up to $80).
    Thanks.
    The Ultimate and the Ultramax use a THU004 handle
    The Drake uses a THU068 handle
    Lowes Hardware will sell a replacement fill valve, the Korky Quietfill, and the repair part for it.
    Korky 528MP MaxPerformance
    and they carry the Red and the Blue 3" flappers when you need a replacement. Also make by Korky.
    Any standard side mount trip lever should work for it, I believe the Eljer might work there.
    The book price on a chrome THU004#CP Toto lever is $23.00
    Feb 2006
    Thanks for your help.
    Last night I happened to be at my local privately run hardware store to pick up something else. In the plumbing section, they had an Eljer side mount lever that looked like it would work. Took it home and installed it. It was about 1/2 inch too long, but after cutting the end off with a hacksaw it worked great.
    DIY Junior Member exoricst's Avatar
    May 2011
    Chicago
    Default IN CRISIS!! Toilet part broken near Lever. Help needed URGENT!! - TOTO Ultramax II
    Hi all,
    I am in a very tricky situation, while moving the toilet up to the first floor i accidently banged the toilet lever area on the door frame, and the lever knob came off. This is a new toilet, and it arrived just yesterday. And i was bringing this up to install it, while this accident happened.
    The black plastic part that was holding the lever has broken. I am posting some pictures here. Please advice if i can buy a replacement of this black plastic part. This is a Toto Ultramax Elongated 1 Piece Toilet MS604114CEFG
    Also i wanted to confirm if the lever rod is good or not. Cos it seems like a little curved.. like bent. See picture below.
    Please advice. My original old toilet is already removed, and we are without toilets right now.
    May 2011
    Chicago
    The part sits here on the outer side of the tank just below the lever.
    You can either buy the THU004 Toto replacement, or pick up an Eljer Style side mount lever at a hardware store.
    In the meantime, you can leave the lid off and pull the flapper up when needed.
    May 2011
    Chicago
    Thanks for the suggestion Terry, i ordered THU004 online, and using the toilet without the lid
    What a way to start..
    DIY Junior Member RoyV.'s Avatar
    Oct 2004
    Illinois
    Default Toto 85411S Ultramax Flush Handle
    It appears that the flush handle to our Toto 85411s Ultramax broke. Does anyone have a part number for this or is there a universal one that will fit. If a universal won't fit, where can I purchase one online.
    Did a quick google search and it seems it's not an uncommon problem.
    Thanks,
    Roy
    Apr 2012
    New York, NY
    Quote Originally Posted by RoyV. View Post
    Thanks,
    Roy
    ITs the THU004 in whatever color or finish you want. Btw, your toiket would be 854114, with the ss114 seat. The lever is availabke at totousa.com and many online sources. Just Google it.. Come back with any questions!
    Oct 2004
    Illinois
    The Eljer side mount lever worked perfectly!!!! Thank you so much.
    Roy
  1. Replies: 3
    Last Post: 06-14-2011, 07:22 AM
  2. Toto flush lever
    By jeffdt in forum Toilet Forum discussions
    Last Post: 02-17-2010, 12:47 PM
  3. Toto Toilet compatible with Delta Victorian lever?
    By FunNut in forum Toilet Forum discussions
    Last Post: 11-03-2009, 05:34 PM
  4. Does a Kohler Lever fit on a Toto
    By noreast in forum Toilet Forum discussions
    Last Post: 02-13-2009, 08:12 AM
  5. toto flush lever
    By mjrva in forum Toilet Forum discussions
    Last Post: 01-20-2005, 04:34 PM
